Go Back   Home > Forums > General Interest > Car Audio
Old 31st October 2011, 04:00 AM   #1
Dr Zeus is offline Dr Zeus  United States
Dr Zeus's Avatar
Default Hifonics Brutus 1206D
Ive got this amp on the bench which warants repair. One rail cap vented so I replaced them all. I had the amp working briefly after that, but a few minutes into testing and now all the amp outputs is loud buzzes which are vaugly in relation to the frequency generator's input signal.
I found 0.050vDC on RCA shields so I proceeded to remove Q11 on the driver board. I found Q11 bad, but no other components. I replaced Q11, a 1D transistor: MMBTA42. There is no longer DC on RCA shields but the amp still produces massive distorion/buzz.
One more thing, if I increase te input signal strong enough, speaker outputs start to produce slight DC. Once ~2v hits, the amp goes into protection.
Old 31st October 2011, 07:18 AM   #2
Try replacing Q7 as well. It may be open.
Old 31st October 2011, 12:51 PM   #3
Dr Zeus's Avatar
Q7 is fine. I fixed this amp; found I had not made good solder connections on Q11 when I replaced it last night. This amp is up and working perfectly now.
Thanks!
Old 31st October 2011, 01:04 PM   #4
In the future, replace Q7 and 11 together. They both run too hot and both tend to fail. If you haven't replaced Q7, you'll probably see that it's turned brown from overheating.
Old 31st October 2011, 01:05 PM   #5
Dr Zeus's Avatar
OK I'll replace Q7
Hifonics Brutus BX1605D mike49504 Car Audio 3 25th July 2011 05:12 AM
Hifonics Brutus BX2200d Rabbi Car Audio 29 27th January 2011 02:10 AM
Brutus 1206D started squeaking (like a bird) today rurockn Car Audio 11 14th September 2010 03:54 PM
Hifonics Brutus lee1976 Car Audio 3 20th July 2010 11:19 AM
Problems with hifonics brutus 1206d amp bull28 Car Audio 16 3rd June 2010 02:26 PM
Page generated in 0.07613 seconds (77.77% PHP - 22.23% MySQL) with 10 queries
