Why are my lights dimming...
Old 30th October 2011, 07:00 PM   #21
Mooly's Avatar
Light bulbs (in cars) are low voltage high current devices. This means that a small drop in voltage causes a very noticeable dimming. Swing the supply to a 12 volt 55 watt bulb around 12.5 to 14.5v and you see a big change in light output.
If your alternator can maintain at least 12.5 volts across the battery (give or take depending on battery electroylite specific gravity) then the battery is not going into discharge and as far as the car is concerned there isn't a problem.
Old 30th October 2011, 07:04 PM   #22
Mooly's Avatar
Originally Posted by carshateme View Post
Well I just looked at my volt meter again..it's now sitting at 15 volts now...That's bad, isn't it?
Alternators (the voltage regulator) is temperature compensated. On a cold start (alternator cold) it can be as high as 16 volts for a short time falling away as the alternator heats up. That ensures the battery gets a real chance to recover and accept useful charge.
On a hot day with a hot engine the alternator may only average say 13.8 volts or lower... that's normal.
Old 30th October 2011, 07:07 PM   #23
carshateme is offline carshateme  United States
carshateme's Avatar
Well I am looking at my capicator in my trunk at when I turn my car on...it's reading at 15volts even...it used to sit at 14.4v =(
1995 Buick Skylark Custom: Hifonics HIF2000D amp Big 3 Upgrade 1/0 gauge wire 3 10" ALUM10N Audiobahns XS Power XP2000 battery Sony CDX-GT43IPW head unit 12k Kensun headlights L.E.D back Kensun lights Street Glow blue neon light interior
Old 30th October 2011, 07:07 PM   #24
carshateme's Avatar
That might be the case.. though it's not that cold out right now.
Old 30th October 2011, 07:10 PM   #25
Frank Berry is offline Frank Berry  United States
Frank Berry's Avatar
Capacitor in the trunk? Why?
You might be better off having an additional battery in the trunk.
Frank
Old 30th October 2011, 07:14 PM   #26
carshateme's Avatar
Please don't start w that...I know caps are basically useless...but my battery is brand new...so I'm not worried about it...when it comes down to the time when I need to replace the battery I will buy a kinect battery....just not now.
Old 30th October 2011, 07:26 PM   #27
I suggest that you remove the capacitor in your trunk and install a battery. It needn't be anything special but it will reduce the Ir loss (voltage loss due to the resistance in the power cables) and improve the performance of your audio system.
Frank
Old 30th October 2011, 07:30 PM   #28
carshateme's Avatar
lol I have 1/0 gauge wire going thru my whole system, including the power wire for the amp and ground...so...I don't think resistance is the issue...or maybe it is..I'm not good w this crap.. I'm just a sub/amp guy, not electronic wiring. But at the moment, I'm saving my money for some sundown z12s...not worried about buying another battery. When I get the money...I'll buy one.
Why are my lights dimming...Hide this!Advertise here!
hummers dimming lights Top Shelf Car Audio 6 13th December 2010 06:27 PM
dimming to flourescent Adnancoskun Parts 2 7th February 2009 08:18 AM
Dimming lights skooter Car Audio 12 2nd December 2007 06:10 AM
How do dimming interior/stereo lights normally work in an automobile? Corn-Picker Car Audio 4 23rd March 2004 11:12 AM
Copyright ©1999-2017 diyAudio
