stetsom 14k2 e
this unit have 3 flashes between power and protection with 1 second laps between the 3 flashes, there is no output transistor or ir2010 in the unit at this point, a picture is included. any sugestion?
thanks in advance. |
1 Attachment(s)
here is the picture
Look up the owner's manual. It shows the code for the flashes.
the 3 flashes means that the battery is bad, since I'm working
with a 12V 35amp power supply, I decide to look for loose power supply connection, and founded a loose transformer, tight up and the amp power came up, install all the output transistor, and the amp was playing OK for about 2 min, until I disconnected the remote cable, I heard a spark and all my output transistors went bad, any suggestion? |
check for solder bridges
Thank very much, solder the power connectors, and the area
and that did it. |
fosgate power 1000.2
this amp got 54v on one channel, no shorted
output or drivers, the tl072 have the +15v at pin 8, and 6v at pin 4 instead of -15v any sugestions? |
sorry. wrong place. for this post.
| All times are GMT. The time now is 09:00 AM. |
vBulletin Optimisation provided by
vB Optimise (Pro) -
vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
