Go Back   Home > Forums > General Interest > Car Audio
Old 27th October 2011, 03:21 AM   #1
chipper is offline chipper  United States
Send a message via MSN to chipper Send a message via Yahoo to chipper
Default rockford punch 40ix weird sound coming from channels
Hey i have another project that hopefully won't get the best of me. Anyway i have a punch 40ix pretty nice heavy little amplifier but when its powered up and with only speakers connected to it, it has a weird cracking type sound coming from both channels. I was checking stuff in each channel and i found D7 to be shorted from both sides (A, K, K, A) is this diode suppose to be like this? And i lift it will it change the output?? pls help ha
Feel the PUNCH
Old 27th October 2011, 03:35 AM   #2
schematic for 60ix here:
https://sites.google.com/site/brande...edirects=0&d=1
D7 should not be shorted, actually all diodes should not be shorted. I believe it offers some protection if the amp is wired incorrectly. Someone more than likely shorted +B to chasis.
Old 27th October 2011, 03:40 AM   #3
No not those diodes its near the treble control. I need to know if anything would happen if i lift it? Its shorted and I'm assuming its probably responsible for the channels not playing correctly.
Feel the PUNCH
Old 27th October 2011, 03:46 AM   #4
That diode is connected between the shield and chassis ground. It shorts when 12v contacts the RCA shield. If you had RCAs plugged into the amp, recheck the diode without having RCAs plugged into the amp.
Old 27th October 2011, 03:51 AM   #5
I did right now i took it out of the heat sink and it still reads a dead short either way i check it. Its a 1N4003 diode.
Feel the PUNCH
Old 27th October 2011, 04:04 AM   #6
Replace it. You know it's defective. Let us know if that solves the problem (it probably won't but you have to change it to eliminate it as a possible problem).
Old 27th October 2011, 04:43 AM   #7
You were right! Didn't do a darn thing! Still the same crackling/fart sound. What else should I check next?
Feel the PUNCH
Old 27th October 2011, 05:08 AM   #8
Does the noise change when you plug the RCAs in?
Does the noise stop if you change the crossover card to full range?
Old 27th October 2011, 05:44 AM   #9
First question: it does it regardless if any RCAs are connected or not
Second question: it gets a little lower but is still very audioable and distorted if I try to play music.
Feel the PUNCH
Old 27th October 2011, 05:58 AM   #10
Do you have a scope?
Weird sounds coming from bass guitar Ivchikx Instruments and Amps 5 30th September 2011 11:49 PM
Weird sound coming out from my speakers. motbuddy Solid State 4 21st June 2010 09:13 AM
rockford punch 500.2 scampo77 Car Audio 26 12th April 2010 02:35 PM
Punch 45 - Weird Problem with Start-up bigphil Car Audio 5 30th December 2008 07:59 AM
Rockford Punch 250x2 gti311 Car Audio 6 14th October 2005 07:26 PM
Page generated in 0.09255 seconds (78.31% PHP - 21.69% MySQL) with 11 queries
