kenwood kac9104 cutting out
Old 25th October 2011, 02:55 AM   #1
ian33 is offline ian33
Default kenwood kac9104 cutting out
This amp plays good audio at low volume.when i turn up thegain and bass bost the audio cuts in and out.It act like the amp is losing power.It has 32.1mv on the speaker terminals with no signal.I try two other speakers but no change.any idea what could be the problem?
Old 25th October 2011, 03:27 AM   #2
Perry Babin is offline Perry Babin  United States
Is the voltage (measured directly) across the B+ and ground terminals dropping?
If so, how far does the voltage drop?
Old 1st November 2011, 01:41 AM   #3
The voltage was drouping to 10v .I solder the output and power supply section and it seem to be ok now.
Old 1st November 2011, 10:14 AM   #4
Are any of the output transistors leaking or shorted?
kenwood kac9104 cutting outHide this!Advertise here!
Kerf cutting. castlesteve Multi-Way 6 8th August 2008 08:30 PM
Cutting Aluminum herm Everything Else 124 4th December 2007 05:32 PM
DAC cutting out malcontent Digital Source 10 2nd March 2007 10:19 AM
Cutting MDF Vivek Everything Else 11 22nd February 2004 07:30 PM
Cutting Acrylic elizard Everything Else 22 11th February 2004 02:48 PM
