Go Back   Home > Forums > General Interest > Car Audio
Old 20th October 2011, 08:24 PM   #1
Default punch amp PS fet subs
I am not sure what model this amp is.It has two mosfet in the power supplymtp75n05dh .i have irfz44n and FQP65n06 which one will be a better sub?
The outputs are irf9540 and irf540 can i used buz272 and buz21 for subs?
PC3080-E
Old 20th October 2011, 08:26 PM   #2
PIC
Old 20th October 2011, 08:38 PM   #3
All of the transistors you listed as subs are rated lower than the originals. The reliability may suffer if they're used.
The BUZ transistors you listed were used in some Rockford amps for a short time but I think they went back to the 540/9540. Maybe it was done because the BUZ transistors weren't as reliable.
Old 20th October 2011, 08:42 PM   #4
ok thanks for the info
Old 21st October 2011, 02:41 AM   #5
seankane's Avatar
PC3080-E
The board looks that of a X250.2.
I would replace the MTP75N05HD with IRF3205 and change the gate drive resistors to a 47 OHM in the power supply. Check the 4 P/S drive transistors marked 1A and 2A.
Perry is right on the BUZ fets dont use them. Use the IRF540 and IRF9540 much easier to find and cheaper and more reliable. Check the gate resistors and make sure they are within tolerance and also check the source resistors.
If you have DC present on the bridging terminals after these parts are replaced, let me know I will let you know what resistors to change.
If you have any distortion I can help you determine which SMD diodes are bad. Keep us posted.
Pyramid 46 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 21st October 2011, 08:58 PM   #6
ok i will wait for the originals because i dont want this amp to come back any time soon
thanks
What is Rumble and Punch in Subs? teachjava Subwoofers 56 6th September 2011 07:14 PM
Punch 200.4 PS problem? RJCRAFTS Car Audio 5 25th June 2008 01:21 AM
Wiring for 2 12" Punch subs Flyin11 Car Audio 2 26th September 2007 04:18 PM
Subs - Optimum thickness & EQ PS rick57 Subwoofers 2 18th November 2004 01:11 AM
Modding my Linkwitz Phoenix Subs - more punch? turbodawg Subwoofers 7 14th February 2004 01:58 PM
Page generated in 0.08243 seconds (78.43% PHP - 21.57% MySQL) with 11 queries
