hi every one,
i have a 4 channel stereo car radio, and want more power with it. could i simply put 2 channels in parallel to get a 2 channel stereo output with double the power? (for example, putting the LF and LR in parallel for an L channel). i measured the 4 ground connectors for the speakers, and are all not connected, all open circuit, thus the above question. thank you for helping! |
#2 |
No. It will likely destroy the internal amplifier if you connect any of the speaker wires from the head unit together.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 | |
could you explain a little why it is so? will it hurt the amplifier if i just leave the 2 rear channels unconnected, i.e. no speakers for them? this is because i feel confused with 4 channels, and would like to have a 2 channel stereo system. |
#4 |
No matter how close the channels are matched, there will always be a slight difference. When you connect them, they'll fight each other until the IC shuts down or fails. Failure is more likely.
You can connect only two channels. Make sure that you insulate each of the unused wires individually.
#5 |
Why do you feel confused with 4 channels? Let's clear that away. 4 channels is fairly standard in car audio, so being familiar and comfortable with it would help you greatly IMO.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine |
#6 | |
i was imagining when power is produced by the amplifier, and this power is not given a way out, it will "burn" something out in the amplifier. is this an issue, or designs nowadays can stand such conditions and consider this normal operating condition? |
#7 | |
now, we know how to deal with 2 speakers with 2-channel stereo source in reconstructing the stereo sound field, (ha, just made up my own audio terminology), but when given 4 speakers with 2-channel stereo source, what is the correct way of using them to reconstruct? i'm missing this knowlegde. so i got confused, and rather have a 2-channel system with double the power. but Perry said no, so maybe the only thing i can do is to waste the 2 rear channels, hope that is not wasting power, burning electricity for nothing that is. |
#8 |
You can use your two spare channels to drive larger rear speakers fitted with inductors so that they only reinforce the bass end. Or use them to drive a dual voicecoil bandpass subwoofer in the back. rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow |
#9 |
#6:
I know of no solid-state audio amplifier that can be damaged by having an open speaker output.
#10 |
#8
wow, that's really a good idea! didn't think of that, i think i'll just do that, great! thanks Sreten! |
| GC power Q's | big314mp | Chip Amps | 5 | 23rd November 2007 02:38 PM |
| Forte 1A newbie q's | snilsen13 | Pass Labs | 11 | 2nd April 2006 08:37 PM |
| Newbie - help sourcing parts TGC and Q's | Nordic | Chip Amps | 2 | 31st March 2006 05:48 AM |
| Q's about power/B-volume/Xover/stuffing | yertzl | Multi-Way | 1 | 1st December 2005 04:15 AM |
| jon risch AC Power Line Filter - q's | sunrise | Everything Else | 6 | 27th June 2005 03:48 AM |
| Page generated in 0.10132 seconds (79.04% PHP - 20.96% MySQL) with 10 queries |
