How to get trunk bass into cabin area?
Old 20th October 2011, 01:23 AM   #1
blue934 is offline blue934  Canada
blue934's Avatar
Default How to get trunk bass into cabin area?
a friend has an 06'ish jetta with subs in the well sealed and insulated trunk. he is complaing about low spl and SQ and wants me to build some new boxes. i suggested first cutting some large holes in the rear deck and placing nice transparent grills over the holes to allow bass to freely enter the cab. any thoughts/suggestions? it seems like he is pressuring the dickens out of the trunk but it is muffled in the cab.
David
Old 21st October 2011, 11:50 PM   #2
ppia600 is offline ppia600  United States
Do it, problem solved.
Don't worry... you can always turn the gain down!
Old 25th October 2011, 07:52 AM   #3
Juancolchado is offline Juancolchado  United States
Cars with well sealed trunks are only good for SQ builds, if he truly wants to cut the rear deck of his car, go for it but note that he will be distorting his car, if he is serious about his bass he should invest in a cheap hatchback/suv type car, these are way easier to get high spl levels with half the effort of a trunk build but it is possible, once the rear deck is cut make sure the ports are firing through or face towards the cut area
Old 25th October 2011, 09:13 AM   #4
theAnonymous1 is offline theAnonymous1  United States
theAnonymous1's Avatar
What about a bandpass design with both ports vented through the deck? That would nearly eliminate the trunk from the sound equation and possibly give better cabin gain. Might want to seal the trunk off even better with that approach.
Old 25th October 2011, 03:41 PM   #5
ttimbo is offline ttimbo  Canada
Since you would be willing to cut into rear deck, maybe look into a set of IB subs mounted to rear deck using trunk as box.
Subs will be firing directly into cabin and wouldn't require as much power either, being IB subs.
Just a thought.
Old 25th October 2011, 10:30 PM   #6
carshateme is offline carshateme  United States
carshateme's Avatar
Get a brunco
1995 Buick Skylark Custom: Hifonics HIF2000D amp Big 3 Upgrade 1/0 gauge wire 3 10" ALUM10N Audiobahns XS Power XP2000 battery Sony CDX-GT43IPW head unit 12k Kensun headlights L.E.D back Kensun lights Street Glow blue neon light interior
Old 26th October 2011, 02:36 AM   #7
Brian Oshman is offline Brian Oshman  United States
Don't just hack put the whole deck. This will compromise the integrity of the car. The Jetta is a unibody and removing the deck will weaken the structure of the car. You can cut a couple of holes in it but don't slice the whole thing out.
Old 26th October 2011, 04:59 PM   #8
AKHeathen is offline AKHeathen  United States
band-pass vented through the deck.
How to get trunk bass into cabin area?Hide this!Advertise here!
Sub placed in trunk? ZeNmAc Car Audio 12 2nd September 2010 07:57 PM
Calculating Port Area for a Bass Reflex Cloth Ears Multi-Way 10 3rd January 2009 02:22 PM
