here are the voltages for the two tl072c. is the first one bad?
1. 0.83 2. 0.07 3. 0 4. 0.6 5. 0 6. 4.6 7. 0.87 8. 15 1. 14.8 2. 14.4 3. 14.3 4. .06 5. 14.3 6. 14.5 7. 14.5 8. 15.0 |
#2 |
It has no negative supply voltage.
Is this for an amp that you asked about earlier?
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
there is no negative voltage. yes this is the amp from earlier.
#4 |
Why did you start a new thread?
Post a link to the other thread.
#5 |
#6 |
When you have a thread started for a particular repair, it makes it much easier to help if you add to the thread than if you start a new thread, particularly when you don't include the full model number.
If the op-amps were two of those in the photo, the negative supply voltage is missing. Find the negative voltage regulator and determine why it's not producing any output.
| brutus brz1200 | timwebb | Car Audio | 3 | 19th June 2011 04:02 AM |
| brutus 1600w | timwebb | Car Audio | 29 | 19th November 2010 01:00 PM |
| Page generated in 0.06507 seconds (83.05% PHP - 16.95% MySQL) with 10 queries |
