Hi everyone, I'm new to the board after researching for some help in repairing a PPI A404. I'm a fan of old school PPI equipment and am getting back into the hobby after a number of years being out of it.
![]() That being said, I'm not new to repairing amps including the older PPI's, Orions, Rockford Fosgates, etc. I've actually repaired a number of them in the PPI line including A600, 2075AM's, 4200AM's, etc. But this 404A has got me stumped. For those of you who know more of the inner working of this amplifier, I would appreciate any help into what I need to repair this amp. I'm posting the following data for those certain components that may be of assistance to those in helping with the troubleshooting aspects. PPIA404 Power Supply M1- M8 Mosfets - SMP25N06 - Gate = 3.56V, Drain = 13.67V, Source = 0V CR1 + 2 Rectifiers FESF8DT - Cathode = 22.93V, Anode = -0.465V CR28 + 29 Rectifiers FESF8DT - Cathode = -23.88V, Anode = -0.465V Q1 BDT81 / NPN Bi-polar transistor used as a regulator --> B = 14.94V, C = 37.6V, E = 14.69V CR5 Zener Diode 1N44A - Cathode = 14.95V, Anode = -0.468V Q77 BDT82 / PNP Bi-polar transistor used as a regulator --> B = -15.80, C = -38.40V, E = -15.24V CR26 Zener Diode 1N44A - Cathode = -0.468V, Anode = -15.80V U1 SG3525A Pulse width modulator Pin 1 Inverted Input = 2.6V Pin 2 Non-Inverted Input = 2.598V Pin 3 Sync = 0.22V Pin 4 Osc Output = 0.191V Pin 5 Ct = 2.042V Pin 6 Rt = 4.31V Pin 7 Discharge = 2.511V Pin 8 Soft Start = 4.92 Pin 9 Compensation = 2.309V Pin 10 Shutdown = 0.002V Pin 11 Output A = 3.56V = drives the MOSFETS at the Gate Pin 12 GND = 0.002V Pin 13 Vcc = 13.21V Pin 14 Output B = 3.56V = drives the MOSFETS at the Gate Pin 15 Vcin = 13.21V Pin 16 Vref = 5.20V Output Transistors Q2, Q3, Q6, Q7 - BDT82 B = -1.097V, C = -23.82V, E = -0.570V Q4, Q5, Q8, Q9 - BDT81 B = 0.025V, C = 22.87V, E = -0.549V Q78, Q79, Q82, Q83 - BDT81 B = -0.019V, C = 22.87V, E = -0.549V Q80, Q81, Q84, Q85 - BDT82 B = -1.081V, C = -23.82, E = -0.549V U2 4N25 Phototransistor Optoisolator Pin 1 - Anode = 1.070V Pin 2 - Cathode = 0.02V Pin 3 - N/C = 0.00V Pin 4 - Emitter = -15.33V Pin 5 - Collector = -15.13V Pin 6 - Base = -14.71V U5 LM833N Op amp Pin 1 / Out A = - 5.74V Pin 2 / - In A = - 1.187V Pin 3 / + In A = - 0.467V Pin 4 / - VEE = -15.08V Pin 5 / + In B = - 0.467V Pin 6 / - In B = - 1.187V Pin 7 / Out B = - 5.74V Pin 8 / + VCC = - 6.44V After all this data, everything looks pretty good to me. The power light isn't coming on. The center of PCB LED DS1 does not come on either. DS2, DS3 - Red Power on and Amber Low impedance LED's don't come on either. The LED for the power should come on. I've checked the LED's with the diode check on a meter and they are both good as they light up when checked. I have not hooked any speakers up or any resistor loads to the speaker leads to avoid having the transistors burn up without heatsinking fully installed. I could just put it all back together and chance it on a speaker in the car and see if it works, but I at least would like to have the power LED working before doing that though... I've also checked the electrolytic capacitors and taken them out and they all come up good. I've used capacitance meters, ESR meters, resistance ohm's to see if any were shorted, and even used a Sencore Auto Z Capacitance Checker. I've also checked resistors to see if there were any that were open. I have a scope if there are some waveforms that someone would like for me to check. Also, if anyone who worked for PPI, etc. or somehow has the 404A schematic and especially the voltages for test points and or waveforms for scope use would be extremely appreciative. |
#2 |
I don't know anything about this particular amp but if U5 is being used for audio, it doesn't appear to have any positive supply voltage on pin 8. Find the positive 15v regulator and check it.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
Thanks for the info. I noticed that as well. I compared it with the LM833N in a PPI 2075AM. Pin 8 on that one shows 14.45v. Is it possible that this op amp is bad or it's just more feasible to look for 15 volts from a regulator?
#4 |
There are likely multiple op-amps. Those used for audio will have both positive and negative 15v. If none have positive supply voltage, the regulator has likely failed. If you need help troubleshooting the regulator, post a photo of the regulator and the surrounding area.
#5 |
There are two others that have -6.44 on Pin 8. I was trying to find where a 15 volt could possibly come from. I found one transistor by the other DS1 that was about 10.58V. Another one kind of close to it at 13.58V. I'll probably just take a pictire of the amp as that might be easier. Thanks!
#6 |
A good quality photo would be very helpful.
#7 |
I've attached a couple of photos. I hope they work.
#8 |
The transistors indicated in the attached image appear to be the voltage regulators. Email me the full resolution images if you need more help.
babin_perry@yahoo.com
| FS for flood relief: excellent condition PPI A404.2, US-made old-school car amp | Pallas | Swap Meet | 1 | 21st August 2010 11:00 PM |
| PPI ART Series a404 "v" PPI Powerclass pc450 swap | chemhaz | Car Audio | 2 | 21st November 2008 02:23 PM |
| PPI a404 amp creating noise (squeal) on AM Band | SRITT3 | Car Audio | 4 | 31st May 2008 02:55 AM |
| PPI 2150 AM Dead! Need help or good repair person! | PyroZona | Car Audio | 69 | 5th December 2007 08:39 PM |
| PPI A404 Amp Repair | jschen | Car Audio | 2 | 5th April 2004 09:06 PM |
| Page generated in 0.12440 seconds (82.21% PHP - 17.79% MySQL) with 11 queries |
