I got this in for repair..
The amp powers up and produces both + - rail voltage.. It also produces + - regulated voltages on the op-amps.. Amp has no output.. Any ideas? |
#2 |
Rail to rail oscillation on the outputs?
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
I dont see any..
#4 |
What work has been done on the amp?
#5 |
The amp has output but very very low output ..
No work has been done to this amp |
#6 |
The voltage directly across R140 is -0.01 and R142 is 0
Dont know if this helps any |
#7 |
You need to definitively determine whether there is rail-rail oscillation on the output transistors.
#8 |
Yes the amp has rail to rail Oscillation ...
Still no output.. |
#9 |
When driving signal into the amp, do you have clean signal on pins 1 or 7 of the op-amp indicated in the photo?
#10 |
NO
| MTX Thunder 6500 D | mike49504 | Car Audio | 4 | 21st July 2011 11:01 PM |
| orion hcca250r, kicker zr 1000, mmats d800.2, mtx 6500d, mtx 942, rockford punch 45, | ernie cosillos | Swap Meet | 3 | 12th February 2011 11:14 AM |
| sansui qrx 6500 | sondadareas | Solid State | 0 | 19th September 2009 03:31 AM |
| Help me fix MTX 152 and MTX 500D | hakentt | Car Audio | 94 | 8th December 2008 06:26 PM |
| Page generated in 0.08586 seconds (72.67% PHP - 27.33% MySQL) with 11 queries |
