I have emailed Kicker a few times and have not received any kind of response so I am dead in the water on this amp. I notice that this is not a rare occurance so I figure the schematic is out there. If someone could post it up for send it to me that would be great.
I will go over it and try to keep the Newb questions to an absolute minimum. Thanks in advance guys!
#2 |
What is wrong with the amp?
Green or red board? If it has a date stamped on the board, what is it?
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
Q06 Q07 Q08 and Q09 are burnt out. Already know I have to get all 8 of the power transistors, but since I cant get the schematic I and these are burnt badly I dont know what the part numbers for the replacements are.
I believe the board was red, but I have to check when I get home, I didn't notice anyone mentioning differences of board or dates so I didnt look into that. I will get that info after work. I am going to order the stuff from Digi-key as soon as I know what I am supposed to be ordering. |
#4 |
If the FETS on the other side of the board were Q12-Q15, it's the red board.
The FETs were likely IRF3205s. If only one side was badly burned, you can probably read them on the other side of the amp. Check the 100 ohm gate resistors after removing the power supply FETs. The PNP driver transistors (Q05 and Q11) also commonly fail. I generally use MMBTA56s in place of the originals. You also need to check the output transistors to see if any have failed.
#5 |
I have a scheme where you can send to your email
#6 |
yes red board
#7 |
#8 |
#9 |
Digi-key has botht he IRF3205ZPBF-ND amd IRF3205PBF-ND listed.
The second seems to have a higher current rating than the first so I was going to go with that one, unless the other differences make it incompatable, or not advisable. |
#10 |
They have essentially the same current rating. Either will work.
| KX 1200.1 burnt output inductor | nonprof | Car Audio | 8 | 11th July 2011 04:23 PM |
| kicker 1200.1 | timwebb | Car Audio | 55 | 11th June 2011 11:32 PM |
| Help to understand this schem please! | apr | Instruments and Amps | 11 | 1st January 2009 08:06 PM |
| Tip33.....anyone got a schem. | diesel_tech | Solid State | 9 | 23rd March 2007 11:55 PM |
| help, schem for sherwood | psychosteve | Solid State | 0 | 10th November 2004 05:35 PM |
| Page generated in 0.09648 seconds (77.70% PHP - 22.30% MySQL) with 10 queries |
