Go Back   Home > Forums > General Interest > Car Audio
Old 11th October 2011, 10:05 PM   #1
Default U.S.AMP 2000X
This unit goes to protection (sat) between 3 to 6 hour after
power on. no leakage or shortage transistors, any suggestion?
fluke 50 mhz scope,35 amp power supply,0.5-12v adj power supply, fluke 179,hot air desolder gun, merit multyfuntion signal tracer/generator.
Old 11th October 2011, 10:40 PM   #2
Is it going into thermal protection?
Old 12th October 2011, 02:54 AM   #3
don`t think so, because I shorted the thermistor
and same thin.
Old 12th October 2011, 03:09 AM   #4
When it shuts down, does the power supply shut down or do you simply lose audio?
Old 15th October 2011, 02:57 PM   #5
I let this amp play for over 15 hour at
50 % Of its volume and no problem,
but when Go more than 75 % volume
it goes into Aux mode.
Old 15th October 2011, 04:17 PM   #6
What's your battery like?
Old 15th October 2011, 10:52 PM   #7
What is aux mode?
Old 16th October 2011, 09:47 AM   #8
Sorry, I ment sat mode.
About the battery, I should
I look for?
Old 18th October 2011, 11:13 AM   #9
Look at the voltage your battery is displaying when the amp cuts out-your power supply may be sagging and causing the amp to shut down.
USAmps 2000x Dr Zeus Car Audio 34 21st May 2012 02:47 AM
Modify & build out (2) Western Electric 300B / 2A3 Hammond monoblock amps & UTC LS-5 quality sound Tubes / Valves 0 9th May 2009 03:59 PM
Krell KSA 80 bias & dc offset check & adjust procedure Clouseaupte Solid State 3 9th August 2007 09:39 AM
DIY-AMP <ZAS> Low THD & IM high bandwith murphy Solid State 18 30th December 2005 10:28 AM
Page generated in 0.07688 seconds (78.56% PHP - 21.44% MySQL) with 10 queries
