Go Back   Home > Forums > General Interest > Car Audio
Old 8th October 2011, 03:46 AM   #1
Deadly Sones's Avatar
Default MB Quartz 1000D with "muted" output
Amp originally powered up with no output. I had to resolder several feet on a few power supply transistors and a couple resistors. They seemed to have "popped" the solder joint. After resoldering them all (and a few others for good measures) I get clean output, but the output appears to be muted....
Where would it be muting? It is the 05 model of the MB Quartz ONX1.1000D
Where to check next?
Thanks in advance,
Old 8th October 2011, 04:02 PM   #2
lol... the problem wasn't with the repair... it seems to be with my new imprint... the RCA volts are suppose to be 4v but I'm getting like .18v.... when I removed imprint and hooked back to deck RCA's it works fine. :-)
The ubiquitous 1/2"...um....3/4"...er 1" ?? polycarbonate "dome" tweeter River757 Multi-Way 14 7th September 2011 06:41 PM
MB Quartz 850s wmclean Parts 0 30th December 2010 04:26 AM
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
do matched pair (or maybe a quad) output tubes "aged" at the same rate? jarthel Tubes / Valves 3 9th June 2007 01:05 AM
8" Quartz pipe for Transmission Line speaker MRehorst Swap Meet 0 26th December 2002 11:00 PM
Page generated in 0.06542 seconds (64.66% PHP - 35.34% MySQL) with 10 queries
