I just got another one of theese in for repair..
The boards look nothing alike at all.. Must be 2 different versions of this amp.. I opened this amp up and transistors fell out of it.. Wondering if anyone knows a good replacement for the following transistors.. First one is marked : K214 2nd one is marked: J77 They are both T0-220 AB package |
#2 |
How are those being used? The datasheets that I found indicate that they're only rated for 1/2 amp of current.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
Im guessing the drivers for the outputs.. Here is a pic of the board and i put an arrow to thoose transistors..
#4 |
Are they shorted?
#5 |
The legs are broken
#6 |
I don't have any suggestions for anything similar. If no one else does, try an IRF540 and and IRF9540. I'm assuming that the supply voltage in this amp isn't greater than ±50v.
#7 |
It would appear that MCM has both original part numbers in stock.
Tools - 1. TPI Scope Plus 440 2. B&K 2125 20MHz Dual Trace 3. Sorensen DCR20-50B 4. B&K 4011 5MHz Function Generator 5. Weller WESD51 |
#8 |
Does anyone know thw the value of C13 and C14 ??
The amp is missing them.. |
#9 |
Or any ideas what may work in C13 and C14 locations ?
C13 the negative side of the cap connects to the 3rd leg of the power supply fets - IRFZ34 C13's positive side connects to the middle leg of the IRFZ34 C14 does the same but in the other power supply of the amp.. |
#10 |
Ok i think i might have figured out the value of them..
Next thing is this amp has 4 power supply in it .. 1 supply per 2 channels.. There is also 4 banks of rectifiers in this amp 1 bank per 2 channels.. When trying to power the amp up it will draw excessive current and the outputs will heat up.. If i remove all 4 banks of rectifiers the amp will power up and idle perfectly.. if i try to put just 1 bank of rectifiers in it no matter what supply i put them in the amp goes back to drawing excessive current and the outputs heat up within 5 secs.. Any ideas what to check? |
| A/D/S 850MX | mike49504 | Car Audio | 1 | 5th October 2011 09:14 PM |
| ADS PQ20 | mike49504 | Car Audio | 26 | 25th May 2011 02:50 PM |
| ads 860mx | mike49504 | Car Audio | 8 | 8th October 2008 08:25 PM |
| ads 860mx | mike49504 | Car Audio | 1 | 5th September 2008 07:07 PM |
| Ads Pq10...p440...850mx | Clipped | Car Audio | 7 | 3rd March 2008 06:48 AM |
| Page generated in 0.09082 seconds (78.95% PHP - 21.05% MySQL) with 11 queries |
