A friend of mine decided to run his kenwood amp at 1 ohm when it's only 2 ohm stable. The amp didn't go up in smoke, just went in protect. I took it apart and tested the power fets and the output transistors and some driver transistors and they all tested good. The only thing I'm questioning is the rectifiers. They are reading about .221 voltage drop which seems a little low.
Powering up the amp doesn't blow the fuse, nor will it blow the 5 amp fuse I have inline with the B+. Any suggestions? The amp is the kenwood KAC-8104d. |
#2 |
Figured out the protect problem but the amp won't produce any audio.
#3 |
Does it have positive and negative rail voltage on the output transistors?
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#4 |
Yea it has 12 volts positive and negative on the outputs. I also tested the power fets and I got 61 volts on 2 of the 4 fets. The other 2 read nothing.
#5 |
The 'power supply' FETs are the ones with 12v.
The ones with 61v are the outputs. Did you check all 3 legs of the other outputs to see if any had -61v?
#6 |
I always get them mixed up. I do get -61 volts on the 2 outputs that don't have positive voltage on the center leg. I get -61 volts on legs 1 and 2 of both those transistors.
I also tested these output transistors part numbers C4883A and A1859A. I get 11 volts on the first 2 legs of A1859A and -9.8 volts on the first 2 legs of C4883A. The set of 4 outputs are FB31N20D's. |
#7 |
The 4883 and the 1859 are not output transistors. They are being used as the pass transistors for the 15v voltage regulators.
On Q411 and Q413, you should have had -rail voltage on legs 1 and 3. Recheck this. In the future, give the circuit board designations (silkscreened on the board next to the transistor) for all transistors that you mention.
#8 |
Q411 and Q413 did have - rail voltage on legs 1 and 3.
#9 |
Do you have a scope?
#10 |
That's one thing I don't have yet.
| Stumped on RF Punch 100 DSM amp - help | m109ner | Car Audio | 77 | 19th June 2011 01:41 AM |
| Amp goes into protect mode on high notes | legalizeeit 420 | Subwoofers | 14 | 18th January 2011 06:19 AM |
| Amp keeps going into protect mode... | legalizeeit 420 | Car Audio | 30 | 19th December 2010 09:24 PM |
| Stumped Troubleshooting Amp | salesmonster | Chip Amps | 4 | 22nd December 2007 05:50 PM |
| amp goes to protect, why? | eeyore757 | Subwoofers | 6 | 21st March 2007 11:29 PM |
| Page generated in 0.11777 seconds (73.87% PHP - 26.13% MySQL) with 11 queries |
