Building a custom box...need suggestions - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 2nd October 2011, 04:00 AM   #1
carshateme's Avatar
Default Building a custom box...need suggestions
Okay I'm Building a box from scratch.. went to home depot and bought 3/4 MDF sheet. Got it cut to where I wanted it..cept I measured a piece wrong...which threw off my volume of the box.
The box measure specs 27 x 13 x 11.25
The depth was suppose to be 8.5...but my dumb idiot butt measured it wrong so...now my volume is about 1.65462 now what I am confused of is do I divide it by two...so each box will be getting .82731 volume...there will be a split between.. Now if that is the cast of the volume being .82731.. I won't have a problem. my subs have a volume space of .5 - 1.25 although I wanted my sub space to be 1...but that isn't going to happen..because all my wood is already cut.
Old 2nd October 2011, 04:18 AM   #2
Run both subs in the same airspace.
You're forgetting, the mass of the sub itself is taking up air inside the cube, so you can deal with a bit of that loss due to the size of the unpopulated enclosure.
They're subs, the signal is mono.. unless you're going to run the subs stereo??
Old 2nd October 2011, 04:38 AM   #3
carshateme's Avatar
They're just woofers. so..they're pretty huge...I didn't calculate that part =((( dammit.. now I gotta add some slots in my box..
Old 2nd October 2011, 04:45 AM   #4
well, the good thing is, you'll never make that mistake again.
Old 2nd October 2011, 05:46 AM   #5
carshateme's Avatar
Thinking about adding the end piece and maybe putting a splitter in the middle
Old 3rd October 2011, 02:39 PM   #6
carshateme's Avatar
Okay I changed up my whole box. The current volume is 2.29102, Approx. 1.14551 per box. But my main question is...Is there a way to vacuum out the air in the box...like they do in fiber boxes...where they get the PSI to a -40 or something for deeper bass...because I do not want to do it the poor mans way and put cotton in it. Mind you this is MDF wood..so adding a valve...might be difficult.
Box dynamics: 27W x 13H x 15D. Custom front paneling 9.5 inch circles.
Old 3rd October 2011, 02:52 PM   #7
Saturnus's Avatar
Speaker drivers only work as intended at equal air pressure. If you somehow manage to introduce sustained lower air pressure on one side it will bottom out the speaker, so basically it can't play anything. It's similar to adding massive amounts of DC on the terminals. Permanently.
Old 3rd October 2011, 02:54 PM   #8
carshateme's Avatar
Lame...because of a friend of mine had 4 rockfords and did it to his fiber box and boy...did they pound...reached 195dBs
1995 Buick Skylark Custom: Hifonics HIF2000D amp Big 3 Upgrade 1/0 gauge wire 3 10" ALUM10N Audiobahns XS Power XP2000 battery Sony CDX-GT43IPW head unit 12k Kensun headlights L.E.D back Kensun lights Street Glow blue neon light interior
Old 3rd October 2011, 03:28 PM   #9
I think you misunderstood or were misled by your friend.
Old 3rd October 2011, 04:21 PM   #10
carshateme's Avatar
Dude, you always trying to downsize me... I know what he did, I watched him do it.. I watched the dB meter. DON'T TELL ME what I saw and what I didn't...
custom sub box help with plexiglass prelude95si Construction Tips 1 16th September 2010 07:13 PM
building a custom circut, is it possible? scampo77 Car Audio 1 3rd December 2009 08:58 AM
Building Custom 2way Towers, design questions sonenelson Multi-Way 4 9th June 2009 12:36 PM
My custom sub box audiobahnkid592 Car Audio 4 13th March 2007 04:19 PM
Building my first 4th order BP box, any suggestions? theCat Subwoofers 8 23rd May 2005 04:01 PM
Copyright 1999-2017 diyAudio
