Orion MBR not charging - Page 6 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 21st November 2012, 05:21 PM   #51
manina is offline manina  Germany
Input voltage 13,44V
Output 8,32
Current draw 1,3A
Q8
1: 17,48
2: 11,43
3: 11,7
IC2
Pin 1: -0,1
Pin 2: 0,35
Pin 3: 0,35
Pin 4: -0,1
Pin 5: 1,4
Pin 6: 3,27
Pin 7: -0,1
Pin 8: 17,4
Pin 9: 14,39
Pin 10: 14,48
Pin 11: 17,49
Pin 12: 17,5
Pin 13: -0,1
Pin 14: 4,84
Pin 15: 0,3
Pin 16: 0,3
black probe connected to the supply (-)
Old 21st November 2012, 07:53 PM   #52
Is R16 within tolerance?
Do you read more than about 0.1v across any of the diodes D4-D15?
Old 22nd November 2012, 09:18 AM   #53
R16 as well as r14,15,17,18 are all OK
D4 to D9 are all reading 0,16V
On the other side, it's more funny
D10 0,14V
D11 0,10V
D12 0,16V
D13 0,22V
D14 0,16V
D15 0,146V
Old 22nd November 2012, 11:09 AM   #54
If you ground pin 16, does the output go full-on?
Old 22nd November 2012, 12:13 PM   #55
No significant changes - just a 0,2V increase
Old 22nd November 2012, 01:57 PM   #56
Does the output go full-on if you jump from pin 7 to pin 3?
Old 22nd November 2012, 03:20 PM   #57
Actually, it drops from 8,5V to 5,8V
Old 22nd November 2012, 03:24 PM   #58
Leave the pin7-3 jumper in place and post the voltage on all pins of the 494 again.
Old 24th November 2012, 09:50 AM   #59
Input voltage 13,7V
Output 6,2V
Current draw 1,3A
IC2
Pin 1: -0,08
Pin 2: -0,08
Pin 3: -0,08
Pin 4: -0,08
Pin 5: 1,4
Pin 6: 3,3
Pin 7: -0,08
Pin 8: 14,8
Pin 9: 11,8
Pin 10: 11,9
Pin 11: 19,9
Pin 12: 14,5
Pin 13: -0,08
Pin 14: 4,9
Pin 15: -0,08
Pin 16: 0,56
Old 24th November 2012, 03:24 PM   #60
Pins 8, 11 and 12 should be at the same voltage. Re-check to see if there was an error when measuring or if the voltage is actually lower on pins 8 and 12.
charging capacitor joeyd71 Car Audio 4 4th April 2009 08:24 AM
Orion NT 200 vs Orion 2150 SX Clipped Car Audio 3 12th June 2007 01:55 PM
Self Charging Capacitors?! Rarkov Parts 4 6th August 2003 07:06 AM
MBR series Piersma Solid State 0 9th March 2003 07:08 PM
Pick-up of charging spikes Jamie F Solid State 19 11th January 2002 12:52 PM
Copyright 1999-2017 diyAudio
