Orion MBR not charging
Old 2nd January 2013, 08:09 PM   #81
Perry Babin is offline Perry Babin  United States
Wasn't there a problem with the voltage on pin 12 of IC2 dropping when the output was loaded?
Old 3rd January 2013, 01:16 PM   #82
manina is offline manina  Germany
Basically, yes. It drops from nearly 30V to around 17 and the output voltage is around 8V instead of more than 13V
Old 3rd January 2013, 06:09 PM   #83
You stated that the output from the diode looked the same (on the scope) loaded or unloaded but the output of that diode feeds pin 12 directly. How can the voltage be dropping on pin 12 but not on the diode.
Old 3rd January 2013, 07:42 PM   #84
Sorry - I may have provided a misleading information. English is not exactly my first language
The curve is almost the same (no spikes or any other strange modifications) but it goes down in the y axis reflecting the changed voltage.
Old 3rd January 2013, 10:07 PM   #85
Look at the signal on the non-striped end of the diode with the scope. Does the waveform drop on that side of the diode when loaded?
If so, post the waveforms when loaded and unloaded.
Old 4th January 2013, 01:22 PM   #86
Here they are.
Image 1 is unloaded and 2 is loaded
Old 4th January 2013, 10:25 PM   #87
If the amplitude of the waveform on the other side of the diode doesn't drop significantly, the diode is likely defective.
Old 5th January 2013, 01:06 PM   #88
This is the other side of the diode
Old 5th January 2013, 08:02 PM   #89
Earlier, you stated that there was no difference between the loaded and unloaded waveforms on the tabs of Q3 and Q4. Now that you know that amplitude is important, do you see a difference loaded/unloaded?
Old 6th January 2013, 11:46 AM   #90
These are the images of the Q3 (1&2) and Q4 (3&4).
Unloaded and loaded
Orion MBR not chargingHide this!Advertise here!
charging capacitor joeyd71 Car Audio 4 4th April 2009 09:24 AM
Orion NT 200 vs Orion 2150 SX Clipped Car Audio 3 12th June 2007 02:55 PM
Self Charging Capacitors?! Rarkov Parts 4 6th August 2003 08:06 AM
MBR series Piersma Solid State 0 9th March 2003 08:08 PM
Pick-up of charging spikes Jamie F Solid State 19 11th January 2002 01:52 PM
Copyright ©1999-2017 diyAudio
