Orion MBR not charging
Old 30th November 2012, 05:18 PM   #71
manina is offline manina  Germany
It's a DSO203
Seeedstudio Forum • View topic - DSOQuadV2.6 RESOURCE(Update 2012/04/12)
You can find a manual in the first post of this discussion. Counting from the bottom of the file list, it's the fifth
Old 30th November 2012, 07:58 PM   #72
Perry Babin is offline Perry Babin  United States
Set the timebase to auto and the vertical amp to 5v/div. Ground the probe to the ground terminal of the amp and touch the probe to pin 9 of IC1. Post a screen cap of the waveform.
Old 2nd December 2012, 11:43 AM   #73
This is the waveform with no load.
Old 2nd December 2012, 04:04 PM   #74
Confirm that the tabs (or center legs) of Q3 and Q4 have the same signal. If they do, post a photo of the waveform on the tab of either transistor both loaded and unloaded.
Old 3rd December 2012, 05:19 PM   #75
There is no difference between loaded and not loaded but there is difference between Q3 and Q4 - see attached files
Old 3rd December 2012, 06:49 PM   #76
Set the scope to DC coupling (not AC coupling), 10v/div and post two photos. One with the probe on each end of D2.
Old 4th December 2012, 03:15 PM   #77
These are the two ends of D2 without load - with load they looks pretty the same
Old 4th December 2012, 04:57 PM   #78
Post the waveforms for Q3, loaded and unloaded. This time, make sure that the coupling is set to DC. You will have to set the vertical amp to 10v/div.
Old 4th December 2012, 06:26 PM   #79
number 1 is the unloaded while 2 is loaded
Old 2nd January 2013, 08:55 AM   #80
I guess I have no hope to fix it
Orion MBR not chargingHide this!Advertise here!
charging capacitor joeyd71 Car Audio 4 4th April 2009 08:24 AM
Orion NT 200 vs Orion 2150 SX Clipped Car Audio 3 12th June 2007 01:55 PM
Self Charging Capacitors?! Rarkov Parts 4 6th August 2003 07:06 AM
MBR series Piersma Solid State 0 9th March 2003 07:08 PM
Pick-up of charging spikes Jamie F Solid State 19 11th January 2002 12:52 PM
Copyright ©1999-2017 diyAudio
