Orion MBR not charging
Old 6th January 2013, 08:38 PM   #91
Perry Babin is offline Perry Babin  United States
Does the voltage on the collector of Q1 drop when the output is loaded?
Old 7th January 2013, 08:41 AM   #92
manina is offline manina  Germany
Yes, there is a 0,6V drop, from 13,6 to 13V on the multimeter.
The scope gives these two images. The almost flat line is the unloaded.
Old 7th January 2013, 07:59 PM   #93
A drop of 0.6v shouldn't be a problem.
Always use DC coupling on the scope unless otherwise instructed.
Post the waveforms on Q3 again with DC coupling.
Old 8th January 2013, 08:27 AM   #94
Here they are - unloaded (#2) and loaded (#3)
Old 8th January 2013, 08:34 AM   #95
How does the DC voltage on pin 8 if IC1 change from loaded to unloaded?
Old 8th January 2013, 11:52 AM   #96
It goes down from 5,4V (unloaded) to 4,6V (loaded)
Old 8th January 2013, 04:35 PM   #97
Is R2 within tolerance?
Old 9th January 2013, 08:08 PM   #98
R2 is much higher than what is supposed to be. I'll swap it tomorrow as I have not a spare one in house right now
Old 10th January 2013, 01:52 PM   #99
R2 changed and the output is back to normal
I put the MBR back in the car and turned on the system - all looks OK.
A big thanks to Perry for the support and figer crossed that it will work for a while without further issues otherwise ->
Orion MBR not chargingHide this!Advertise here!
charging capacitor joeyd71 Car Audio 4 4th April 2009 08:24 AM
Orion NT 200 vs Orion 2150 SX Clipped Car Audio 3 12th June 2007 01:55 PM
Self Charging Capacitors?! Rarkov Parts 4 6th August 2003 07:06 AM
MBR series Piersma Solid State 0 9th March 2003 07:08 PM
Pick-up of charging spikes Jamie F Solid State 19 11th January 2002 12:52 PM
Copyright ©1999-2017 diyAudio
