where can i buy the pads to go under the transistors?
T timwebb Member Joined 2010 2011-09-28 2:37 am #1 2011-09-28 2:37 am #1 where can i buy the pads to go under the transistors? ••• More options Share CBS240 Member Joined 2005 2011-09-28 2:55 am #2 2011-09-28 2:55 am #2 Mouser is a good start. There are different types of thermal insulators. Some require heat sink grease, like mica. I like mica pads because it has low thermal resistance and is very cheap. ••• More options Share Show hidden low quality content Status This old topic is closed. If you want to reopen this topic, contact a moderator using the "Report Post" button.
