Go Back   Home > Forums > General Interest > Car Audio
Old 27th September 2011, 01:32 PM   #1
Default Regulator Question..
On the circuit board its marked L7812 L7812A..
The middle pads are connected directly to the caps negative terminal..
When i looked at the regulators they are marked 7912 but appear to have been switched from the orginals..
My question is Should the be 7812's that belong in this amp not the 7912's ?
And also wondering since the middle leg connects to the caps ground is there no possible way that they can be the 7912's that go there?
Old 27th September 2011, 01:45 PM   #2
firechief's Avatar
7812 is the positive version. Installing a 7912 in that spot would require reversing cap, cutting and hacking, and gettin a negative voltage from somewhere. This is really not likely. Yes the middle leg on the 7812 is grounded, and common to the tab. I would be cautious here, if you haven't turned this thing on, better find out what was done before applying power. Good Luck.
"You can keep your insurance baby nothing is guaranteed" -Tom Petty
Old 27th September 2011, 01:55 PM   #3
Thanks..
The in leg for both regulators connect to 100uf 63 volts caps positive terminal..
middle legs connect to the caps negative terminal..
3rd leg connects to the caps positive terminal..
So the 7812's should be the correct part??
Old 27th September 2011, 02:18 PM   #4
Yes.
Regulator Heatsink Question LyleCaldwell Power Supplies 15 14th April 2005 12:26 AM
A 3-Pin Regulator Question saurus Solid State 3 27th October 2003 01:54 PM
regulator question fezz Parts 12 16th April 2003 03:10 PM
Regulator question Mark Hayenga Solid State 2 9th January 2003 08:11 PM
BOSOZ regulator question audionut Pass Labs 1 5th July 2002 04:40 PM
Page generated in 0.06700 seconds (71.32% PHP - 28.68% MySQL) with 10 queries
