#11 |
I took Ohm reading of all the listed transistors again.
IRZF48 Leg 1-2 230KOhm |
#12 |
Sorry it took my post too soon
IRZF48 (8 total, they all measured about the same) Leg 1-2 230KOhm Leg 1-3 300Ohm Leg 2-3 -200KOhm TIP36CW (4 Total) Leg 1-2 300KOhm Leg 1-3 300KOhm Leg 2-3 -200KOhm TIP35C (4 Total) Leg 1-2 150KOhm Leg 1-3 300KOhm Leg 2-3 225KOhm SF104 CT (2 Total) Leg 1-2 Between 500KOhm or it would climb to open Leg 1-3 0.2Ohm Leg 2-3 500KOhm Let me know what else I should be checking, thanks |
#13 |
Now start checking the smaller transistors on the board in the defective channel. If none read shorted, compare their readings to the corresponding transistors in the other channels.
Links >> Basic Car Audio Amp Repair * Basic Car Audio Electronics * New Site * Basic Switching Power Supply Design * Basic Computer Skills << Links |
#14 |
I ended up pulling the board out of the amp base to reach the bottom pins of the transistors because I couldn't reach them from the top. I think I have my defective section narrowed down, there is a green wire going from Channel 4 to 1 of 4 identical squares of pieces. I checked the smaller transistors(anything with 3 legs?) and none were shorting out. A few would read open between points, but they seemed to be doing that all over so I don't think that is a problem. I did not write down all the measurements I took because I'm in a hurry, I have to leave for work in a few, but nothing seemed extremely low or out of whack. I read quite a few in the 200KOhm range. I will try to get a more accurate comparison between the channels next. If those come back ok what should I check next? Resistors, Capacitors? Thanks again for all the help.
#15 |
You can check the resistors. The larger resistors sometimes fail with no visible damage. The smaller ones generally burn when they fail but you can check them to be sure.
Look for broken solder connections or anything else that could be a problem.
| Soundstream Rubicon 1002 | mike49504 | Car Audio | 6 | 30th November 2010 03:41 PM |
| Soundstream Rubicon 302 | mike49504 | Car Audio | 20 | 6th June 2010 02:09 AM |
| Soundstream Rubicon 204 amp. need help ! | minde16v | Car Audio | 3 | 23rd November 2009 07:38 PM |
| Soundstream Rubicon 702 Issue | Lobby Ludd | Car Audio | 4 | 24th September 2008 06:21 PM |
| Soundstream Rubicon 805 | audiobahnkid592 | Car Audio | 16 | 23rd July 2008 10:13 PM |
