Go Back   Home > Forums > General Interest > Car Audio
Old 26th September 2011, 06:39 PM   #1
Default MTX 6500D
Amp powers up and idles perfectly..
On the power supply fets 1 get
Leg 1:0
Leg 2:13.8
Leg 3:0
I get all different readings on every op-amp
Amp produces no audio..
Any ideas?
Old 26th September 2011, 07:46 PM   #2
That's normal for this amp.
Do you have rail to rail oscillation on the outputs?
Do you have rail voltage?
Is the gain set to the maximum position?
Have you operated all switches and pots through their entire range with speakers connected to see if the amp produces any sound (noise or audio)?
What op-amp readings vary (AC, DC, include pin numbers)?
Old 26th September 2011, 08:37 PM   #3
I have both + - 59 volts of rail voltage..
I get oscillation from rail to rail ..
Gain is set to maxium posistion..
If i mess with the gain pot i can get the spear to thump back and fourth..
Im gonna try switching the pot out to see if that fixes the problem if not i will post back with voltages on op-amps
Old 26th September 2011, 08:41 PM   #4
Don't try to swap the pot. If you're using a used pot, it's likely going to be damaged when you remove it from the board.
What specifically is wrong with the readings from the op-amps?
Old 26th September 2011, 09:01 PM   #5
First op amp
Pin 1:17.16
Pin 2:15.14
Pin 3:15.79
Pin 4:1.44
Pin 5:11.46
Pin 6:10.61
Pin 7:17.26
Pin 8:18.04
2nd op amp
Pin 1:16.53
Pin 2:16.53
Pin 3:16.57
Pin 4:1.43
Pin 5:16.58
Pin 6:16.50
Pin 7:16.50
Pin 8:18.10
3rd op amp
Pin 1:16.59
Pin 2:1.18
Pin 3:0.57
Pin 4:1.43
Pin 5:16.59
Pin 6:15.96
Pin 7:17.24
Pin 8:18.12
4th op-amp
Pin 1:2.67
Pin 2:2.67
Pin 3:2.04
Pin 4:1.42
Pin 5:2.04
Pin 6:2.66
Pin 7:2.66
Pin 8:18.13
5th op amp
Pin 1:17.46
Pin 2:1.44
Pin 3:0.77
Pin 4:1.42
Pin 5:1.44
Pin 6:2.19
Pin 7:2.66
Pin 8:18.14
6th op amp
Pin 1:-1.82
Pin 2:0
Pin 3:0
Pin 4:-18.22
Pin 5:0
Pin 6:0
Pin 7:0
Pin 8: 17.44
Old 26th September 2011, 09:12 PM   #6
You're missing the negative 15v on most of the op-amps.
Find the PZTA56 near the op-amps that has -rail on the collector. What is the voltage on the base and emitter?
There may be two PZTAs that have -rail on the collector so don't stop looking for the PZTA56 after you find one.
Old 26th September 2011, 09:30 PM   #7
Base:-59.6
Emitter:1.30
The other 1 has the following voltages..
Base:0.5
Collector:1.3
Emitter:1.3
Old 26th September 2011, 09:33 PM   #8
It could be an A92. Possibly next to D118.
Old 26th September 2011, 09:37 PM   #9
The A92 has
base:-17.95 volts
Emitter:-17.92 volts
Old 26th September 2011, 09:41 PM   #10
That one is OK. Which A56 did you find earlier with -rail on it?
If you can't see the circuit board designation, what are the designations for the components connected to it?
MTX 6500d radwilsons5803 Car Audio 9 4th May 2011 07:10 PM
orion hcca250r, kicker zr 1000, mmats d800.2, mtx 6500d, mtx 942, rockford punch 45, ernie cosillos Swap Meet 3 12th February 2011 11:14 AM
MTX 6500D m4ick Car Audio 14 2nd February 2011 12:43 AM
Mtx 6500d mike49504 Car Audio 17 17th January 2010 07:45 AM
Page generated in 0.10705 seconds (80.97% PHP - 19.03% MySQL) with 10 queries
