Go Back   Home > Forums > General Interest > Car Audio
Old 25th September 2011, 02:12 AM   #1
carshateme's Avatar
Default Where to put the fuse
Okay...sure ya'll are sick of me asking questions but I'd rather do my setup right rather than do it wrong.
Bought a KnuKonceptz 0/1 gauge with a 250A fuse; a 3.5 soundquest farad capacitor aka lightning cap, and a Hifonics HIF2000d 2000 watt rms amplifier. (Amp is so beasty...about 1.7ft long...)
Well question: Need to know rather to put the fuse by the battery (my last fuse was mounted under the hood next to the battery on the frame.) or mount it in my trunk...I was told that where I had my last fuse mounted was a bad idea, so I'm asking you guys.
Sub settings: 2 audiobahn ALUM10N 3200 watt/ 1600 rms max
and yes. I plan on making myself deaf..*trust me I'll have like 6 pairs of earplugs in. =P*
Old 25th September 2011, 02:16 AM   #2
Send a message via AIM to DigitalJunkie
ALWAYS put the fuse nearest to the battery. It can save your car from turning into a BBQ in case the power cable rubs-through and shorts to the frame somewhere -The fuse will blow.
Now think about what happens if the fuse is in the trunk,and the wire were to short out... no fuse=no protection=no more car.
Old 25th September 2011, 02:32 AM   #3
carshateme's Avatar
Thank you. =] But if that was the case...It would fry my lightning cap and possibly my amplifier.... my system costs more than my car.
Here's a case:
Can I put more than one fuse on a power line...one at the battery terminal...one for the cap and one for the wire b/w the cap and the amp?
Old 25th September 2011, 02:54 AM   #4
It shouldn't damage anything. The amp will just suddenly not have any power,no big deal. The cap might dump all of it's charge into the shorted wire,but it shouldn't damage the cap..that's better than having the car battery dumping all of it's charge into the shorted wire!
(Ever short out a car battery? It can get REALLY ugly REALLY quickly. Fire,explosions,boiling acid flying everywhere,etc,etc.)
Also,if the system does cost more than the car,it is IN the car,right? So if there were a mishap,you would lose the system AND the car in the resulting fire.
Put the fuse near the battery. Trust me. Anybody who says differently is full of it.
Old 25th September 2011, 03:00 AM   #5
You MUST have a fuse at the battery unless you want to risk losing both the car and the system.
You can have more than one fuse. Generally, there is one fuse at the battery to protect the vehicle and another set of fuses near the amplifiers to protect the smaller wires going from the distribution block to the amps.
Hifonics recommend using nothing larger than a 200 amp fuse. If you only have one amp being powered by the main power wire, you can use the recommended fuse at the battery. If you're using multiple amps (assumed), you'd use whatever fuse is necessary to protect the wire. You'd then use the correct size fuses for the amps and short lengths of wire in the rear of the vehicle.
While Hifonics recommends a 200 amp fuse, there is virtually no way for that fuse to prevent the amplifier from being damaged if something goes wrong. A 125 or a 150 amp fuse would likely be large enough and would be much better at protecting the amplifier.
You should read the following page:
FUSES
Old 25th September 2011, 03:02 AM   #6
carshateme's Avatar
Actually It's not atm, lol all I have right now is the amp...just bought it yesterday...which was scary because I always shop on amazon and the amp got delivered in a day..
But yeah, I see what you mean, was being a smart ***...The current fuse I bought is a 250A fuse...and I'm going to be buying another 250 a fuse for in between my amp and cap.
But I am only running one amp because the hifonics is overpowering my subs by 100 rms...so don't want to damage them.
Old 25th September 2011, 04:04 AM   #7
just like perry said, always have a fuse within 12-18" from the battery connection, no larger than the safe current "ampacity" that the wire is rated for at the distance. now, if your amp suggests smaller fusing, you can add more fusing by the amp for that. actually it works out well to use the fuse by the amp as a distro block. i have seen first-hand the after-math of an un-fused 8awg cable, and it was not pretty indeed. in fact, cost about 1300 just to get the vehicle drivable, and that did not include carpet, trim, and smell. now, just imagine what a large cable can do. fire, exploded battery, etc. just make sure the fuse holder is sealed from elements and use the provided cable sealing grommets, and any o-rings. any surface that is not a good seal can be made to seal better with Vaseline or grease. would last just as well as an interior fuse location
Old 25th September 2011, 02:31 PM   #8
carshateme's Avatar
Okay Thank you. My plan is to put a fuse under my hood, next to the battery, where I had my old fuse and take my old fuse case and replace it with a 250A fuse and put it in my trunk.
I have one of these... what should I put it in? Sideshow88 Subwoofers 3 4th April 2010 11:28 AM
Fuse housing melting but fuse not blowing, ppi amp rawadia Car Audio 21 2nd August 2008 10:39 AM
Why main fuse and not rail fuse? digital desire Solid State 10 3rd December 2006 08:07 PM
amp rating for fuse and fuse holder? riotubes Parts 5 27th August 2006 03:10 AM
Page generated in 0.10481 seconds (81.01% PHP - 18.99% MySQL) with 10 queries
