Go Back   Home > Forums > General Interest > Car Audio
Old 22nd September 2011, 08:22 PM   #1
chipper is offline chipper  United States
Send a message via MSN to chipper Send a message via Yahoo to chipper
Default Distorted LF channel on punch 200a4
I have a punch 200a4 here that has a distorted channel I removed the transistors for that channel and tested them they came out good. But when I put them back in the circuit the channel is still distorted. The other 3 channels work perfectly. I tried to check all the surface mount transistors and resistors all of them measured out good. Any ideas what's going on?
Feel the PUNCH
Old 22nd September 2011, 10:54 PM   #2
seankane's Avatar
Be sure to check the ones marked 5D and A7.
The 5D is a switching diode with leg 3 being cathode and leg 1 being annode.
The A7 is a dual switching diode with leg 1 as annode and leg 2 as cathode and leg 3 being a common connection.
The annode is where the current flows in and the cathode is where it flows out.
I have found these 2 diodes to be distortion causes many times in Rockford amps.
Also check the A56's and A06's for that channel as well as the 0.1 ohm 2 watt source resistors.
I have had a bad smd resistor cause distortion as well. Take your time start tracing the circuit from the output fets and testing all things in-line.
Does the channel that is distorted have any significant DC present?
Pyramid 46 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 23rd September 2011, 02:23 AM   #3
All of the above mentioned I took my time carefully and checked each smd component and those checked out good. But I did find Q103 labled "2A" defective it's a smd PNP transistor shorted one side reads .579 and the other side is shorted. What if I remove this from the circuit?
Feel the PUNCH
Old 23rd September 2011, 03:00 AM   #4
Q103 is shorted by design.
Do you have a scope?
Old 23rd September 2011, 03:16 AM   #5
Oops! I took it off! And no I don't have a scope. I tried locating possibly a transistor like on the 201S but i couldn't find any.
Feel the PUNCH
Old 23rd September 2011, 03:50 AM   #6
Lift D101 and D102, one at a time, checking for distortion after lifting each one. Does that eliminate the distortion.
RF Punch 200a4 nearly the same as 400a4? gisewhcs Car Audio 6 12th September 2011 09:24 PM
Rockford Fosgate Punch 200a4 chipper Car Audio 7 26th March 2011 03:01 AM
Punch 500a2 distorted channel chipper Car Audio 62 21st March 2011 09:02 PM
RF Punch 200a4 Noise faul Car Audio 4 22nd October 2010 05:24 AM
Help!! Right Channel Freq distorted. TPC Tubes / Valves 3 16th January 2003 02:27 PM
Page generated in 0.08499 seconds (76.48% PHP - 23.52% MySQL) with 10 queries
