I got a Lightning audio LA1.150.2 amp that I'm checking out for a friend. I unsoldered all the power FETS and output fets and tested them out of board and the outputs came back with .303 volts. I had another amp laying around with the same outputs that tested good and used those. I unsoldered 4 driver transistors by the IC and they all tested fine. I tested the gate resistor and it too tested fine.
I'm not sure what else to test. I have been reading Perry's BCAE1.com site to double check a lot of things. If anyone has any ideas, I'd appreciate the help. Thanks |
#2 |
The protection circuit may be damaged.
If the outputs were FETs, they could read 0.3 if they're not checked in the right way. Contact Lighting to get the schematic diagram and send me a copy. babin_perry@yahoo.com
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
The FET's are IRFZ46N transistors. I checked them out of the board the same way I checked the IRFZ46N's that I had removed from another amp and .3 seemed a little low. All the other FET's in the other amp measured .6 volts. I'll get a hold of lightning audio and see if they will send me a schematic.
I have a memphis amp where the gate resistors melted the board and I can't find where the traces are. I emailed memphis and they wouldn't give up a schematic. Hopefully I can get one from Lightning Audio. Thanks for the help |
#4 |
The Z46s are likely the power supply FETs, not the output transistors. If you don't discharge the gate, they can pass current which will make them appear to be defective. That's why I recommend shorting the gate to the source when testing.
Lightning has, in the past, supplied schematic diagrams for their amps. If you have a question about a Memphis amp, start a new thread.
#5 |
I did have a thread open in the class D section but didn't get many replies. I'll email lightning audio and get back to you. Thanks.
#6 |
The class D forum is mainly for people building class D amplifiers. If it's a class D car amp, you would need to post the question here.
#7 |
Thanks for clearing that up. I was a little confused on where to post.
#8 |
After waiting forever for Lightning Audio to reply to my inquiry, they said they don't service those units and they don't have a schematic on hand.
#9 |
You'll need to post good quality photos of the inside of the amp. If you need help taking good quality photos read this:
Basic Amplifier Repair
#10 |
| Lightning Audio Storm S1.1000 | m4ick | Car Audio | 22 | 3rd August 2011 08:53 PM |
| lightning audio 1000 d amp from the closet | ppia600 | Car Audio | 2 | 14th February 2010 10:11 PM |
| Lightning Audio 2000watt Class D | confused256 | Car Audio | 19 | 29th December 2009 03:35 AM |
| lightning audio amp repair | doughboi916 | Car Audio | 14 | 31st August 2007 09:05 PM |
| class d lightning audio (rockford) 1000 watt help | zfactor | Class D | 2 | 5th April 2005 08:57 PM |
| Page generated in 1.04664 seconds (9.49% PHP - 90.51% MySQL) with 11 queries |
