Can I use an amp power wire for speaker wire
Old 21st September 2011, 06:08 PM   #1
carshateme is offline carshateme  United States
carshateme's Avatar
Default Can I use an amp power wire for speaker wire
I know it sounds ghetto but I was just looking at some competition speaker wire and it looks just like the power wire that I have now. I don't want to spend $27 on 25ft of speaker wire if I can use my old power wire. Thanks.
Old 21st September 2011, 06:26 PM   #2
toprepairman is offline toprepairman  United Kingdom
That's probably because it is just like the power wire you already have.
Spend your money on some CD's and enjoy.
Henry
Old 21st September 2011, 06:28 PM   #3
carshateme's Avatar
So I can use my power wire for speaker wire?
Old 21st September 2011, 06:33 PM   #4
That's a definite YES.
Old 21st September 2011, 06:34 PM   #5
carshateme's Avatar
Ah thank you very much. : )
Old 21st September 2011, 10:29 PM   #6
AKHeathen is offline AKHeathen  United States
ummm, actually, if your using power wire the size of your speaker wire, i would be more concerned. i'm assuming that you are speaking of 8awg wire? so, if you are throwing 40a at your sub(s), you are definately drawing over 100a from your car, in which case, you need to be 2awg+ at runs over 8'. can get away with 4awg under 8'.... i use 8awg @ 1k+ per coil...... just what is your setup?
Old 21st September 2011, 11:19 PM   #7
carshateme's Avatar
Uhhh.... lmao no. I was looking at some 8ga competition wire n it looks like the 8ga power wire i have hooked up now. But my setup is a 2000w rms hifonics hif2000d amp w 2alumn10n woofers along w a knukonceptz 0ga power wire.
Old 22nd September 2011, 12:01 AM   #8
oh, lol. just making sure. yah, i keep 8awg around for only 2 things- 2ch mid amps up to 250, and sub wires. sometimes, it's cheaper than good 12/2-10/2 speaker wire
Old 22nd September 2011, 11:59 PM   #9
ghettorabbit6 is offline ghettorabbit6
higher gauge wire is less resistance. ive noticed in using a d4 sub with direct soldered leads of 8g my final load with the coils wired in paralell my impedence was under 2 ohms 1.8 or so slight difference but makes ur amp make more power.
Can I use an amp power wire for speaker wireHide this!Advertise here!
litz inductor wire for speaker wire. fazman Everything Else 126 20th June 2011 02:48 PM
how to wire an LM386 chip amp to a speaker pacislander007 Construction Tips 1 8th September 2009 12:40 AM
22 AWG silver plated solid copper wire for speaker wire? G Full Range 21 15th February 2009 09:32 PM
Amp4 Mod Round-up Ė Input wire, power caps and high capacitance speaker cable Peteruk Class D 10 4th April 2007 06:12 PM
Power amp loading on house wire chris ma Everything Else 10 22nd June 2004 11:51 PM
Copyright ©1999-2017 diyAudio
