smd parts smd parts - diyAudio
smd parts
smd parts
Old 18th September 2011, 11:13 PM   #1
timwebb is offline timwebb  United States
Default smd parts
i wanted to make sure this was right. the marking om the part is 2t on a cart i have it says its 2n44403. is this correct?
Old 19th September 2011, 12:08 AM   #2
seankane is offline seankane  United States
seankane's Avatar
Its actually 2N4403 you have to many 4's in the part number you listed.
2T
p2T
t2T
All of those are the same 2N4403 part number
Try using MMBT4403 when looking up the part. They are all SOT23 package and from what I could find: PNP 80V 100Ma
Pyramid 52 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 19th September 2011, 12:49 AM   #3
ok thanks!
Old 19th September 2011, 01:57 AM   #4
Perry Babin is offline Perry Babin  United States
If you have any MMBTA56s on hand, they will generally serve as a suitable substitute for the 4403.
Old 21st September 2011, 12:04 AM   #5
can i replace 2N4401 with MMBTA42?
Old 21st September 2011, 12:12 AM   #6
Are these for the same section as the previous transistors you asked about?
How are they being used in the amp?
What amp is it?
Old 21st September 2011, 12:18 AM   #7
yes.the output drive transistors. one side of out puts works as it should. the other side is making the speaker osc really bad. all 640's are brand new
Old 21st September 2011, 12:20 AM   #8
Please answer all of the questions.
Old 21st September 2011, 12:25 AM   #9
yes its for the same section.its
being used in the output driver circuit.
an audio pipe 1800
Old 21st September 2011, 12:35 AM   #10
The a42 is a slower transistor and may run hotter. I'd suggest that you wait and get all of the correct parts for this amp. Class D amps can be finicky and using subs (especially multiple subs) could cause problems. The problems may not be immediately apparent and could cause reliability issues later. If the amp is unreliable or fails while testing, you won't know if it's the drivers or something else.
smd partsHide this!Advertise here!
Bag of mixed SMD parts jkeny Parts 1 2nd November 2009 02:02 PM
Is there any difference between SMD and TH parts? nelsonvandal Solid State 43 24th November 2008 02:39 AM
yet another Mini-A layout... (with SMD parts) BrianGT Pass Labs 32 3rd March 2004 12:28 AM
Comparison of SMD parts to standard parts BrianGT Parts 0 2nd July 2002 09:09 PM
Copyright ©1999-2017 diyAudio
