Go Back   Home > Forums > General Interest > Car Audio
Old 16th September 2011, 03:10 AM   #1
timwebb is offline timwebb  United States
Default quick question
whats the best way to discharge the rail before putting the output transistors in? i was thinking about mounting some power resistors to a heat sink for for use as a dummy load and another for current limiting.
Old 16th September 2011, 04:25 AM   #2
What amp is this?
Resistors are the best way. 4-10 ohms work well. The lower the resistance, the larger the arc when you discharge them. If you use 25w or greater resistors, you don't need to have them on a heatsink. If you use smaller resistors don't touch the body of the resistor. No matter what resistors you use, don't touch the wire or leads for the resistor.
Old 16th September 2011, 04:31 AM   #3
the audio pipe im workin on. i have to a few hours before i can put the output transistors in cause the current from the rail shorts them out as soon at it touch the pads.
Old 16th September 2011, 04:38 AM   #4
If it's out of the sink, you can short across the rail caps with the resistor. If it's in the sink and you want to discharge them before you handle the board, short between the output leg of the rectifiers and any of the secondary windings.
Don't slip and short between the legs of the rectifier because it may burn through the legs on the rectifier.
quick question ultra Car Audio 0 3rd September 2011 01:32 AM
quick question timwebb Car Audio 10 28th March 2011 12:38 AM
Quick question Metra90 Car Audio 3 29th May 2010 05:10 AM
Quick quick question ! guitvinny Pass Labs 6 7th February 2007 04:20 PM
Page generated in 0.06950 seconds (71.24% PHP - 28.76% MySQL) with 10 queries
