Go Back   Home > Forums > General Interest > Car Audio
Old 26th September 2011, 04:00 AM   #131
It's zinc oxide in a silicone base. Solder it across the other diode for now.
Yes, the black diode on the side of the white diode.
Old 26th September 2011, 05:30 AM   #132
SomeGuyInPDX's Avatar
Replaced diode to the right of "F". My last fuse popped on power up I will recheck as soon I find another fuse. Thanks Matt.
Old 26th September 2011, 09:16 AM   #133
The amp seems to be working now!!!
w/15 amp fuse, both speakers seemed to be loud and clear.
After hooking the amp back up in the car I must have done something wrong because now both channels sound great individualy but with the balance centered the subs seem to drop in volume and loose there bottom end. any idea's?
Old 26th September 2011, 09:18 AM   #134
One speaker out of phase (wires reversed).
Old 26th September 2011, 05:03 PM   #135
Perry Babin is an Amp Repair GOD!!! Everything seems to be working fine(pic#1).
I just need to put the wiring looms covers back on to clean up the look. You were correct; one of the subs must have been out of phase although I think it may be in the box. I triple checked the speaker wires and they are all correct going to the box.
Is there a way to check the box's terminals with a meter to tell what side of the speaker is going where or do I just pull the subs and look?_
Or should I be using the mono low pass output(pic#2 ) since one of the outputs is inverted?_
I am not trying to be lazy here; it’s just that they are behind a false wall when viewing from the trunk/outside. It is there so when hauling stuff it cannot contact and hurt the speakers, and to the untrained eye, you cannot see anything.
This has been a great learning experience for me, I learned a lot on your website, and it is a great reference for us "Electronically challenged" people. I do have to say nothing teaches better than doing it. There were things that I read that made no sense until I was testing those parts "hands on", it was then that I could start to grasp how it operated.
Again, thank you so much.
Old 26th September 2011, 05:27 PM   #136
If you can see the speakers, you can use a battery to see if they're in phase.
http://www.bcae1.com/images/swfs/speakerphase.swf
Unless you really just want to know where the problem is, it's not really important. If it's producing good bass, the speakers are in phase.
Old 26th October 2011, 11:22 PM   #137
Back Again. The amp is still running but I have noticed that the right channel(the repaired one) is not producing full power. I have switched the RCA's to verify that one channel wasn't getting a stronger signal but that wasn't it. So I switched the subs to see if that may have had something to do with it, but still the same result. After running the amp at about 1/3 power for 5-10min the left half is noticably warmer to the touch than the right channel. Right channel seems to have about 1/2 to 2/3 the power that the left channel is producing. since this amp is actually two 2 channel amps bridged, I'm starting to think only one of the 2 channels is working on the right channel.
I checked the gain pots again and both channels are getting 1v input.
any idea's anyone_?
Old 26th December 2011, 05:48 AM   #138
EnvisionAudio's Avatar
any idea's anyone_?
I've got two of these amps on the bench. Both had a leaky transistor that controls the amplitude voltage driving the bases of the power supply switching transistors. It would produce a high output voltage which stressed the filter caps and cause that half to run warm.
Perry might be able to elaborate.
DCX2496/DEQ2496 Car Audio Conversions
www.envisionelec.net
Old school Orion XTR 2250 DanielJ Car Audio 28 28th October 2011 11:31 AM
Orion XTR 2250 OLD SCHOOL wyteboy Car Audio 2 10th April 2011 10:54 PM
Old School Orion 2150 gx.I must repair this amp spooney Car Audio 99 21st August 2010 02:53 PM
Old School Orion,Class B? amc32 Car Audio 1 31st January 2010 09:19 AM
couple old school orion questions Clipped Car Audio 3 5th August 2006 10:09 PM
Page generated in 0.09444 seconds (79.60% PHP - 20.40% MySQL) with 11 queries
