Go Back   Home > Forums > General Interest > Car Audio
Old 14th September 2011, 02:21 PM   #1
Default Help with PPI PC 21400.2
Hey if anyone is out that can give me the values of R172 and R79 would be very helpful. I just got this amp in for repair and the southside part of the power supply all the fets were shorted a couple were blown, along with half of the gate resistors and also the resistors that i stated above. Any help would be great
Thank you
Old 14th September 2011, 04:16 PM   #2
Can you post a photo of the board showing the location of the resistors?
Old 14th September 2011, 05:00 PM   #3
yes here it is one of my employees replaced them with what he thought was right but i dont want to power it up and them be wrong.
Old 14th September 2011, 06:57 PM   #4
The closest thing I have photos of is a 2350. In the 2350, R79 is definitely 10 ohms. I think R172 is probably also 10 ohms. If it connects to the mylar cap in the same way, it's almost certainly 10 ohms.
Old 15th September 2011, 04:43 PM   #5
Great thanks for the help. I replaced those and it powered up then all i could hear was a small click turns out it shorted out some power transistors they are shorted out in an alternating order should i replace the pwm and the other two ic's
Old 15th September 2011, 04:58 PM   #6
The HIP4081s typically fail when the FETs fail so you'll likely need to replace those.
They're shorted in an alternating pattern because the banks are interlaced. In this amp there are 4 banks of FETs.
If you find the FETs that read less than ~40 ohms between the gate and the other legs of any individual transistor, you can remove those from the circuit an determine if the drive circuit has been damaged also.
Old 15th September 2011, 05:22 PM   #7
Your such a huge helP and reply so fast thank you I will get everything ordered and replaced and I will let you know after. Thanks again perry you're always helpful
PPI PC 21400 mike49504 Car Audio 42 31st July 2011 06:49 AM
ppi pc 2150 xover 90Hz (fix) carlinux Car Audio 3 9th July 2011 04:52 PM
PPI PC 6600.2 mike49504 Car Audio 17 14th October 2010 06:52 PM
PPI PC 2150 mike49504 Car Audio 2 12th October 2010 03:06 AM
ppi pc 6600.2 - Help Please 07SS Car Audio 3 28th November 2007 02:36 PM
Page generated in 0.08543 seconds (84.71% PHP - 15.29% MySQL) with 11 queries
