Ran into one of these that had the fillter burned loose from the board.
replaced filter, and everything is working fine, but the unit just sounds a little odd. its hard to explain. But then i noticed when the amp is idling not only does it making noises, but if i turn the volume knob up and down, you can watch the speaker push in and out. paying closer attention to the speaker when music is playing, it seems like the DC offset is just swinging around, almost like a broken RCA ground as seen with a previous amp. But it is not, I am getting a .3xx reading on diode check beween RCA ground and speaker ground. (no RCA connected). so i assume trouble in op-amp circuit. any ideas? |
#2 |
You shouldn't be reading below 1 ohm between the 'input' RCA ground and the speaker -.
Check D198 and D199.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
I didnt take the measurement in ohms. I took it in Diode Check. had about .4XX or so voltage drop. between spk and rca shield. no RCA was connected.
#4 |
0.4 on diode check isn't a problem.
In some of the MTX amps, when the VCA (THAT 2180/2155) fails, it will cause a surge of DC when you adjust the gain. You can jump them from pin 1-8 with a 1k resistor to eliminate them as a possible fault.
#5 |
yea, its definately somthing. Because with or without the RCAs connected, you can vary the gain and the speaker just pushes in or pulls out before it settles.
And it sounds kinda "muddy" or a box full of bass. its hard to explain. it doesnt sound "normal" per say. probably the offset playing a role into the audio. because it shifts around alot when the music is on. |
#6 |
Did you try jumping the VCA out?
#7 |
not yet. the customer took his amp back and said heck with it.
Anyway, whats the VCA do? |
#8 |
The VCA is a voltage controlled amplifier.
In MTX amps, it's used to adjust the signal level in the amp. Its main purpose is to adjust the signal level when the remote level controller is connected. In amps with a compressor, it is supposed to reduce the signal level to prevent hard clipping.
| orion hcca250r, kicker zr 1000, mmats d800.2, mtx 6500d, mtx 942, rockford punch 45, | ernie cosillos | Swap Meet | 3 | 12th February 2011 11:14 AM |
| MTX Thunder 8302 issue | mbates14 | Car Audio | 14 | 5th January 2011 12:42 AM |
| MTX Thunder 6152 issue | gsg529 | Car Audio | 10 | 7th July 2010 12:45 AM |
| mtx thunder81000d | timwebb | Car Audio | 12 | 26th May 2010 07:06 PM |
| MTX 421D supply issue | brandes.cm | Car Audio | 39 | 21st April 2010 01:28 AM |
| Page generated in 0.08391 seconds (78.41% PHP - 21.59% MySQL) with 10 queries |
