Coustic AMP-360 repair
Old 24th October 2013, 05:59 PM   #11
Hanatsu is offline Hanatsu  Sweden
Dunno if I should post in a new thread, but since it almost covers the same issue I'll post here
I found an old Coustic AMP360 and one channel is out. Reading 27V+ on left channel speaker output and the red "peak" LED lights up as soon as I power it up, even without load. At idle it draws ~1A so there's no abnormal current draw.
I'm not very good at troubleshooting electronics but I assumed it was shorted output transistors and replaced them (TIP142/147) but it did not help, turns out the old transistors was ok. I measured the voltage over the output transistors with an o-scope and it shows a steady DC 27V over both Base, Collector and Emitter. Removed the transistors again and there was still 27V DC on the base, I suppose it should measure close to 0 when there's so signal? I measured the resistance of the small transistors around the output stage but nothing seems shorted.
No visible sign of damage anywhere on the board, checked all the big caps, the bias pot and the small transistor in the middle of the output transistors but they seem all to be ok.
Anyone got a schematic over the board? Any ideas?
Old 20th August 2015, 07:14 PM   #12
swedude is offline swedude  Sweden
i have the same problem as you dunno but on amp-260 powerlogic from coustic. did you solve the problem?
Old 6th September 2015, 02:07 AM   #13
Alaraune is offline Alaraune  Mexico
Check SMPS
Coustic AMP-360 repairHide this!Advertise here!
old coustic 360 amp fongman Car Audio 45 31st July 2013 09:05 AM
O/S COUSTIC AMP-460 vs. 460u 404Amps Chip Amps 1 17th December 2010 12:53 AM
Coustic AMP-460 Repair??? 404Amps Car Audio 1 3rd December 2010 09:57 PM
Coustic 360 test damage Car Audio 1 20th November 2009 12:55 PM
Old school Coustic Amp 160:turns on with no remote power spooney Car Audio 17 16th August 2008 05:33 AM
