Another Rockford Fosgate Punch 200ix repair
Old 7th September 2011, 02:28 PM   #11
cebby is offline cebby  United States
Originally Posted by seankane View Post
Set your meter in ohms with the range on auto and measure the rsistance between the gate and source legs of all 4 power supply fets. That would be leg 1 and 3 looking at the fet from left to right, what do you get?
The board location of these fets is Q10,Q11,Q6,Q7
Next measure the gate drivers resistance the little smd resistors marked 510 what do you get? These are 51 ohm and should read somewhat close to that.
The board location of these resistors is R31,R36,R32,R37
Here are the values:
Q10 - 7.35 m ohm
Q6 - 7.34 m ohm
Q11 - 7.25 m ohm
Q7 - 7.24 m ohm
R31 - 51.1 ohm
R36 - 51.1 ohm
R32 - 51.0 ohm
R37 - 51.0 ohm
Old 7th September 2011, 02:31 PM   #12
Originally Posted by Perry Babin View Post
As a side note...
On this site (and others), if you type anything that would take more than 1 minute to re-type, highlight the text and copy it to the clipboard (ctrl-c or right-click and select copy) before clicking anything that will move you from the page where you typed it. It's happened to me so many times that I always do this for long posts.
Most sites (that I visit anyway) don't timeout that quick anymore - I've run a number of forums over the years and that value is one of the first things I change.
I just need to keep it short and sweet.
Old 7th September 2011, 04:11 PM   #13
seankane is offline seankane  United States
seankane's Avatar
With the amp powered on what is the the DC voltage on the gate legs of the power supply fets, that leg being the first leg from left to right.
Pyramid 52 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 7th September 2011, 07:45 PM   #14
It's weird - these were fluctuating some, plus when I went through and remeasured, all of the values had dropped.
Q10 - .850 - dropped to .811
Q6 - .905 - dropped to .825
Q11 - .934- dropped to .832
Q7 - .955 - dropped to .833
Old 7th September 2011, 09:54 PM   #15
Perry Babin is offline Perry Babin  United States
Most Rockford amps have a bit of voltage regulation for the rails. They quickly go to full duty cycle when driven into a load but at idle, the duty cycle of the drive signal is reduced. This will make the measured DC voltage relatively low at idle unless the DC input voltage is low.
If you have a regulated 12v power supply with a variable voltage, decrease the voltage. The gate voltage should increase as you decrease the 12v supply voltage.
If you do this, check the voltage on the gate resistors. There will be less of a chance of damage if the probes slip.
Old 8th September 2011, 01:04 AM   #16
Ah OK - that makes perfect sense to me. Do those sound like acceptable numbers - and is that much of a disparity (over .1 volt) between Q10 and Q7 normal?
Let me see what I can find figure out on the power supply.
Old 8th September 2011, 02:12 PM   #17
I don't see any problems with the numbers you posted.
Old 9th September 2011, 12:45 AM   #18
seankane's Avatar
Do you have the means and part to replace the IN4003 and then to further test the amp?
Old 9th September 2011, 05:59 PM   #19
I need to order the part - I'm comfortable replacing it.
I was hoping to place a bigger order through identifying more bad parts first. If it helps with the process, I'll order the part and get it swapped out for further testing.
Old 9th September 2011, 06:42 PM   #20
Rectifier Diodes (25-Pack) - RadioShack.com
Another Rockford Fosgate Punch 200ix repairHide this!Advertise here!
Rockford Fosgate Punch 200ix seankane Car Audio 2 4th June 2011 01:02 AM
Rockford Fosgate Punch 200IX seankane Car Audio 64 12th May 2011 12:48 AM
rockford fosgate punch z stevena2006 Car Audio 2 23rd December 2009 04:20 PM
Repair of Rockford Fosgate Punch 201s Jackson75 Car Audio 15 3rd November 2009 10:34 PM
rockford fosgate punch 200ix transformer plays music? spooney Car Audio 2 15th October 2007 12:04 AM
