Another Rockford Fosgate Punch 200ix repair - Page 3 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 9th September 2011, 08:14 PM   #21
seankane's Avatar
I think it would be best to replace that part first then continue trouble shooting in my opinion. What caused the part to fail is the question???
Following some of the traces on some of my parts boards it looks like that part is tied in with the cross over card, the power supply driver transistors, the PWM TL494C, the LM339, and the voltage regulators. Maybe you had an issue in one of those areas.
What is the output on the positive and negative voltage regulators with the amp powered up?
Post the DC voltage of the pins on the TL494C and the LM339.
Go to alldatasheet.com if you are not sure of the pin locations and post as follows.
Pin 1:
Pin 2:
etc....etc...
Pyramid 52 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 9th September 2011, 09:58 PM   #22
This is board 766. Are you working from that diagram? The two 200ix diagrams I have are different. I'd suspect that that diode is the one that connects between the shield and primary ground. If that's the case, it's generally damaged when 12v is allowed to contact the shields.
Old 9th September 2011, 11:20 PM   #23
seankane's Avatar
I have several different boards the one I am looking at is a 766.
Thats makes sense because normally when I find Rockford amps with broken rca shield pins from the board I have to replace the IN4003 or the amps have wierd feedback noises and other strange problems.
To burn such as in the pic he posted you would think the 12v contact must have been for a long pieriod of time.
Maybe other issues could cause it as well, I have seen a few that burned but not very often.
Old 25th May 2012, 07:02 PM   #24
I have one I want to repair too. It was driving 2 punch 18's @ 4 ohms bridged. Failure was likely the cause of driving hard into clipping over extended play. I have replaced all the caps in the power supply C13,C30,C12,C15,C22,C24,C16C28,C25 all with the appropriate caps.
many fets on the output side were visible damaged so I removed all pairs and replaced them with IRF 540 as called. When I power it up the led lights dimly and Q11 gets hot finally burned and popped the fuse. I need to get it idling before i can run a signal through it and see what I got signal wise.
When q11 is good i measure 28mohms on each fet q11,q6,q7,and q10
board version PC-0766-C
help me please !
Hugh
Old 25th May 2012, 07:10 PM   #25
Pin 1:
Pin 2:
etc....etc...
should be +15 and -15 volts
Old 25th May 2012, 10:49 PM   #26
Start a new thread. Copy and past your posts from here into the new thread.
Old 25th May 2012, 11:02 PM   #27
ok
Rockford Fosgate Punch 200ix seankane Car Audio 2 4th June 2011 01:02 AM
Rockford Fosgate Punch 200IX seankane Car Audio 64 12th May 2011 12:48 AM
rockford fosgate punch z stevena2006 Car Audio 2 23rd December 2009 04:20 PM
Repair of Rockford Fosgate Punch 201s Jackson75 Car Audio 15 3rd November 2009 10:34 PM
rockford fosgate punch 200ix transformer plays music? spooney Car Audio 2 15th October 2007 12:04 AM
Copyright 1999-2017 diyAudio
