JL Audio 500/1
JL Audio 500/1
Old 11th September 2011, 11:53 PM   #11
Perry Babin is offline Perry Babin  United States
Q508 and Q502 are also drivers.
Old 12th September 2011, 02:35 AM   #12
mike49504 is offline mike49504  United States
Ok amp powers up and idles perfectly..
2 of the outputs have 82 volts of rail on them..
Other 2 outputs have no voltage on them..
Any ideas?
Old 12th September 2011, 02:47 AM   #13
You need to be more specific. Each of the 4 transistors has 3 legs.
What is the DC voltage on the speaker terminals (one positive and one negative terminal) with the black probe on the amp ground?
Old 12th September 2011, 02:56 AM   #14
With Black meter probe on ground ..
Positive speaker terminal:0.14 volts
Negative speaker terminal:0 volts
On the outputs
Q504 and Q507 show 82 volts of rail on the center legs..
On Q505 and Q506 I get 0.04 volts on all 3 legs of each output
Amp has no output
Old 12th September 2011, 05:04 AM   #15
If you short pins 1 and 2 of the op-amp indicated in the photo, do you get any square wave oscillation on the outputs?
Be careful, if it's shutting down for some reason, this could cause it to draw excessive current.
Old 12th September 2011, 05:26 AM   #16
im gonna test that in a few..
My question is on the regulator U601 (7805) are legs 2 and 3 connected together ??
Because from leg 2 to leg 3 i get 26 ohms is that normal for this amp?
Old 12th September 2011, 05:51 PM   #17
I've never had any reason to measure the resistance between those two legs but it seems too low. Pull the regulator and check the board and regulator to see where the low resistance is.
Old 12th September 2011, 08:07 PM   #18
im getting the 26 ohms on the pads themselfs from 2-3
Old 12th September 2011, 09:38 PM   #19
Do you still read low resistance if you unplug the preamp board?
Old 13th September 2011, 02:21 AM   #20
yes
JL Audio 500/1Hide this!Advertise here!
Jl audio 500/1 Transistor clamps spooney Car Audio 9 16th September 2014 04:36 PM
Jl audio 500/1 powers on with low audio out help needed ivkata Car Audio 29 19th August 2011 12:21 AM
JL Audio 500/1 mike49504 Car Audio 1 15th August 2010 09:02 PM
jl audio 500/1 megael9 Car Audio 12 28th May 2010 11:01 PM
JL Audio 500/1 repair info Bertje Car Audio 11 30th October 2009 12:52 PM
