Hey Guys
I wanted to ask about powering a car audio system at home. I know this question has been asked many times, but I thought I'd ask specific to my case. Firstly some background information. Basically I have gone and bought the following Sony Xplod XS-GTF1627 These are 4 Ohm speaker and they have a peak power of 190W and 40W RMS. These were on sale for $25 bucks a few months back. Couldn't resist for this price, So i bought one. Jensen Power Amplifier (P400) This amplifier can provide 75 Watts (RMS) per channel for 4 Ohm Speakers. This is a dual channel amplifier. In the manual it says it draws a maximum current of 25A (Also has a 25A fuse inserted in the amplifier). Is my understanding correct? It'll have a average current pull of 6.25A? P = V*I 75 = 12 * I I (RMS) = 6.25A (RMS) ? Nothing special about this amplifier. I bought this purely out of impulse shopping. Got this amplifier for $70. Automedia AM-3100BT This is a 50 x 4 Watt (Peak Power) car head unit. In the manual it says it runs on 12V, but it didn't specify what's the rated current. However there is a 10A fuse installed in the Unit, so assuming maximum rated current of 10A. Just like the car amplifier. Nothing special about this head unit. Just bought it with the car amplifier. I need to power both the head unit and amplifier. I was looking into purchasing a PSU off ebay (NOT PC PSU!!) to run the entire system. What do you guys recommend for me to do, in terms of powering the whole system? If a PSU is recommended, is it ok to choose a PSU that is able to provide more current then the system can handle or choose one that will provide less current? I have looked through ebay for power supplies, like the one below. 350W DC 12V 29A Triple Output Switching Power Supply | eBay |
#2 |
As long as the supply will deliver 12 V, you'll be fine. Actually, battery voltage is closer to 13.8 V, but that's another story. The difference from 12 V to 13.8 V is not worth worrying about. I'm just saying you have a little margin there.
If you get a supply that can't supply the current the amp draws at max power, the supply voltage will sag at the max load and you won't get full power out. The amp will clip and the sound will be horrible (if you haven't blown the speakers by then anyway). If you get a supply that can supply more current than the amp will draw, that means you have margin. I.e. regardless of how much power the amp delivers to the speakers, the supply will deliver the rated output voltage. Note, however, that many switchmode supplies require a minimum load for stability. Make sure the current draw of your amp is above this minimum current when the amp delivers no power to the speakers (no sound). With linear (transformer-based) supplies this is not an issue. ~Tom |
#3 | |
Do you have any suggestion in how I can go around the stability issue, without resorting to linear PSU's? |
| In Home Car Audio | Relax | Parts | 15 | 8th July 2006 10:56 AM |
| Car Audio At Home | califf123 | Car Audio | 33 | 20th March 2004 12:19 PM |
| car to home audio? | bigpetey | Multi-Way | 1 | 10th February 2004 02:33 AM |
| Car Amp VS Home Audio? | Jay | Car Audio | 1 | 3rd December 2003 04:02 AM |
| Page generated in 0.08580 seconds (75.62% PHP - 24.38% MySQL) with 10 queries |
