I'm sorry, I don't have any information on that amp.
If the components are aligned perfectly straight with the solder pads, there's a good chance that they're the original parts.
Have you tried installing all of the components to see if there is a problem or to determine what sort of problem it has?
I found the problemHI,Perry.I need your help.Do you have the Amplifier photo? This amplifier has been repaired, but still not fix it, some resistors and transistors are not the original model.
R516=471(470 Ohm)
R520=471(470 Ohm)
R528=221(220 Ohm)
