Rockford Power 650 Mosfet
Old 3rd September 2011, 10:04 PM   #11
Perry Babin is offline Perry Babin  United States
The shields and the connection on the boards should read the same so it shouldn't matter which one you use.
Old 3rd September 2011, 10:15 PM   #12
seankane is offline seankane  United States
seankane's Avatar
They both read the same at the board 85.6 M OHMS
One set reads differently out at the end where it plugs in, and the other set reads the same as at the board.
Pyramid 52 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 3rd September 2011, 10:23 PM   #13
From the schematic diagram, it appears that you should have an 82 ohm resistor between the shield ground and the primary (main) ground. If you have another 650, confirm because it's difficult to read the value on the diagram.
All shield grounds also appear to be directly connected on the diagram. Confirm that also if you have another amp there. If one reads differently at the shield than at the board, the shields are broken in the cable.
Old 4th September 2011, 12:25 AM   #14
seankane's Avatar
Yes I have 4 other Power 650's so I will confirm. The rca's were new but does not mean they are not bad. I Will replace them again.
If the rca's had a broken shield inside could this cause the problem I am experiencing?
Old 4th September 2011, 12:38 AM   #15
Open shields can cause all sorts of problems but the specific type of problem varies greatly from one amp design to another.
Old 7th September 2011, 08:07 AM   #16
seankane's Avatar
Ok Perry replaced the new set of rca's with another new set and the problem seems to be fixed. I cant run the amp hard till tomorrow but no more popping and the channels are working fine regardless of the rca's being plugged in front and rear.
I dont know why the new set was bad and the open shield really caused alot of wierd problems with the amp.
SO far everything seems ok let you know after I set the fan and run it hard.
Old 7th September 2011, 08:17 PM   #17
seankane's Avatar
Ok Perry I set the fan threshold and ran the amp hard till the fan kicked on and the fan speed increased as the amp got warmer so I am assuming that it is set correctly.
SO far everything seems to be working A ok no problems. I ran the amp for about 30 min at half volume with no issues.
Thanks again.
Rockford Power 650 MosfetHide this!Advertise here!
Rockford power650 mosfet seankane Car Audio 6 2nd September 2011 09:02 AM
rockford fosgate power 650 mosfet mike49504 Car Audio 43 24th March 2011 11:21 PM
Help with Rockford Fosgate Power 650 shawnk Car Audio 31 14th July 2010 09:11 PM
rockford fosgate power 300 mosfet mike49504 Car Audio 26 23rd December 2009 05:06 AM
Rockford Fosgate/Mosfet steven123654 Car Audio 5 2nd September 2009 03:13 AM
