Go Back   Home > Forums > General Interest > Car Audio
Old 29th August 2011, 06:39 PM   #1
Send a message via Yahoo to Simontempler
Default Planet Audio VX2200D dead need Help!
Hi everyone, thanks for having me.
I am a newbie at this type of amplifier.
Nothing seems burn, what I notice was, when remote terminal have 12v there is a fan that start spin-in, other than that there is no power on the output FET's.
It uses a KA3525A to drive the switch mode power supply. I downloaded the datasheet and I am not getting the voltage reference leading me to believe I may have a bad IC. Need your opinion on this mater.
Listed below are the voltage taken from ic301 KA3525A: using 1ms/5div
01: 0v
02: 0v
03: 0v
04: 0v
05: 0v
06: 0v
07: 0v
08: 0.7v
09: 0.4v
10: 0v
11: 0v
12: 0v
13: 10v
14: 0v
15: 10v
16: 0.4v
Thanks for your assistance in this matter
Old 29th August 2011, 06:55 PM   #2
It could be a defective IC or something dragging the 5v reference down.
10v on pins 13 and 15 is also quite low. There may be another problem if your 12v power supply was at or above 12v.
Old 30th August 2011, 04:33 PM   #3
Acting on your tip Perry I remove ic301 and bread boarded it to see if I can duplicate the problem and sure enough I'm only receiving 0.4v on the reference terminal.
I connected a series resistor to the terminal pin 16 on the board and the voltage drops across it was very minimal the current go through it was only 7 mA this of course without the chip installed.
I wanted to know if I had excessive current draw.
I don't have another chip so I will order some and repost when I get them.
Thanks very much.
Old 2nd November 2011, 08:53 PM   #4
OK fellows, I finally got the pwm ic from eBay and installed it. The amp powers up, I have rail voltage ~60v, the green power light and the protect light stays on I also notice a burn resistor of unknown value at R101 would this be the cause for the protect light to stay on? and what value is that Resistor.
Thanks for your reply.
Old 2nd November 2011, 09:53 PM   #5
R101 is a 220 ohm resistor. I don't think it can cause the amp to go into protection unless possibly if the RCAs are plugged in.
This resistor generally fails when the transformers have (intermittent) shorts or when the positive speaker wire shorts to chassis ground.
This type of amp is covered on the class D - type 2 page of the tutorial. There are a lot of other common problems with these amps that need to be addressed.
planet audio bb2400.1 bdgf2004 Car Audio 76 29th April 2012 06:01 PM
Planet Audio PA2250D spooney Car Audio 24 15th February 2011 04:05 PM
Planet Audio ZR300.4 o. l. t. Car Audio 25 24th May 2010 03:46 AM
Planet Audio VX2200D tdetlor Class D 0 4th February 2010 01:58 AM
Planet Audio amp rader Car Audio 3 7th November 2006 08:50 PM
Page generated in 0.08194 seconds (75.41% PHP - 24.59% MySQL) with 10 queries
