punch 600a4
without the limiter audio is not cuting in and out again.The amp does not power up somtimes.I get 16v on the gnd and B+.My power supply is 12.6v.when i switch of the power supply am still get 16v on gnd and B+.if i dischare the caps the amp comes on with 11.2v on gnd and B+.Is this an indication of bad caps?.
with black probe on amp ground terminal i get 16v and amp will not power on.I i leave it connected for about 60 seconds it will power up.The cap dont discharge sometimes.If they get discharge, when i switch the power supply off it will power up the next time i switch on the power supply.If the caps dont get discharge it will not power on
