Can i used a 1n4001 in place of 1n5818?It is for the power supply of an ESP-2
#2 |
Probably not. The 5818 is a high speed diode with low forward drop. The 1N400x diodes are likely to run MUCH hotter and are likely to fail.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
a look in the datasheet
#4 |
a look at this
#5 |
so what do u think? should i take the chance.The 1n400* and FR51 is all i have for now.I will be getting some others soon .i will list them later
#6 |
not not see the datasheet for
| Parallel diode vs antiparallel diode | phieuxuatkho | Class D | 6 | 31st October 2010 12:54 PM |
| Diode help | dognut | Parts | 2 | 11th May 2009 10:41 AM |
| looking for a diode... | rtate | Solid State | 1 | 21st March 2008 11:10 PM |
| diode bridge - 10000uF cap - diode tube - small cap - HV+ | engels | Tubes / Valves | 5 | 29th January 2008 10:16 PM |
| hybrid power supply: diode bridge into diode tube | engels | Tubes / Valves | 8 | 24th September 2007 09:18 AM |
| Page generated in 0.07144 seconds (72.57% PHP - 27.43% MySQL) with 11 queries |
