memphis 1000d
memphis 1000d
Old 28th August 2011, 11:52 PM   #31
timwebb is offline timwebb  United States
0.5 ohms
Old 29th August 2011, 12:00 AM   #32
Perry Babin is offline Perry Babin  United States
The transformer appears to be shorted. Do you see any windings that appear to be darkened?
If not, try twisting the transformer while measuring the resistance. Does the resistance ever go significantly higher?
Old 29th August 2011, 12:06 AM   #33
yes it does the resistance goes very high.
Old 29th August 2011, 12:11 AM   #34
You'll need to find the short. Do you have a current limiting resistor?
Old 29th August 2011, 12:17 AM   #35
yes.
Old 29th August 2011, 12:27 AM   #36
Insert the resistor between the B+ line and the amp's B+ terminal. Connect the ground from the power supply to the secondary center tap. Make no other connections to the amp. Apply power and twist the transformer. You should hear it arc and you should see a spark where the short is. You'll need to insulate it at that point.
Old 29th August 2011, 12:30 AM   #37
doing it now.
memphis 1000dHide this!Advertise here!
1000D Memphis Amp ? Hoppy72450 Car Audio 11 22nd December 2017 11:25 AM
another memphis 1000d timwebb Car Audio 3 11th April 2011 04:14 AM
Memphis 1000D transformer. tgdrums1990 Car Audio 4 16th June 2010 04:32 PM
power supply issues memphise 1000d jf8620 Car Audio 1 10th May 2006 11:05 PM
Memphis 1000D Transistor Blowing jf8620 Car Audio 46 12th March 2006 11:49 PM
