memphis 1000d
memphis 1000d
Old 28th August 2011, 09:43 PM   #21
Perry Babin is offline Perry Babin  United States
Have you tried installing the outputs?
There may be no problem.
Old 28th August 2011, 09:50 PM   #22
timwebb is offline timwebb  United States
i tried it.one group of 640's get hot and it has dc current on the speaker terminals. i pulled the driver cards out it does the same thing.
Old 28th August 2011, 09:59 PM   #23
Are they new transistors?
Old 28th August 2011, 10:02 PM   #24
yeah i just got them in.
Old 28th August 2011, 10:23 PM   #25
How much DC voltage is there on the tabs of the output transistors (no driver board in the circuit)?
Old 28th August 2011, 10:24 PM   #26
on the card behind the opamps the two pins labeled output and sync has that same signal as before.
Old 28th August 2011, 10:31 PM   #27
12.3 volts
Old 28th August 2011, 10:36 PM   #28
With the black probe on the amp ground, what is the DC voltage on the secondary center tap of the power transformer?
Old 28th August 2011, 10:42 PM   #29
12.5v
Old 28th August 2011, 10:46 PM   #30
Measure the resistance between the B+ terminal and the secondary center tap with no power applied. What's the resistance?
memphis 1000dHide this!Advertise here!
1000D Memphis Amp ? Hoppy72450 Car Audio 11 22nd December 2017 10:25 AM
another memphis 1000d timwebb Car Audio 3 11th April 2011 03:14 AM
Memphis 1000D transformer. tgdrums1990 Car Audio 4 16th June 2010 03:32 PM
power supply issues memphise 1000d jf8620 Car Audio 1 10th May 2006 10:05 PM
Memphis 1000D Transistor Blowing jf8620 Car Audio 46 12th March 2006 10:49 PM
