memphis 1000d
memphis 1000d
Old 28th August 2011, 01:52 AM   #11
Perry Babin is offline Perry Babin  United States
Does it remain on the display or does it go beyond the top of the display?
Old 28th August 2011, 02:30 AM   #12
timwebb is offline timwebb  United States
it goes to the top and stay at the top
Old 28th August 2011, 02:54 AM   #13
Is it still visible at the top of the display?
Old 28th August 2011, 02:59 AM   #14
on its off the screen. if i adjust my probe then it only goes right at the top
Old 28th August 2011, 03:17 AM   #15
There seems to be something very wrong with the scope or the way you're using it. This needs to be addressed before we can use any scope images.
Go to the oscilloscope page of the site, find the 'best initial settings' and set your scope as described there. After reading the text, read the questions under the text and make sure that you can answer all of them.
Set the scope to 0.5v/div and touch the probe to the B+ terminal of your power supply. The trace should disappear beyond the top of the display. Set it to 5v/div. The trace should deflect ~2.5 divisions. Confirm that that's what you see. If not, VERY specifically explain what you see.
Old 28th August 2011, 05:08 AM   #16
ok its functioning the way it should now. at 0.5div the trace leaves the top of the screen.
at 5div it goes up 2.5div. my probe is the 1x-10x probe. wish i would learned this stuff when i was in school.
Old 28th August 2011, 07:10 AM   #17
Now that you have the scope working properly, with no input signal, check the signal on the gates for the audio FETs.
Set the timebase to 5us
Set the vertical amp to 5v/div
Set the coupling to AC (one of the few instances where you'll set it to AC coupling)
Do all of the gates have a square wave?
Old 28th August 2011, 03:12 PM   #18
yes all the gates have a perfect square wave now.
Old 28th August 2011, 10:15 PM   #19
Is it still going into protect mode (or repeatedly alternating between green and red)?
Old 28th August 2011, 10:32 PM   #20
both lights just stay on. the relay will engage.and produce rail voltage.
memphis 1000dHide this!Advertise here!
1000D Memphis Amp ? Hoppy72450 Car Audio 11 22nd December 2017 11:25 AM
another memphis 1000d timwebb Car Audio 3 11th April 2011 04:14 AM
Memphis 1000D transformer. tgdrums1990 Car Audio 4 16th June 2010 04:32 PM
power supply issues memphise 1000d jf8620 Car Audio 1 10th May 2006 11:05 PM
Memphis 1000D Transistor Blowing jf8620 Car Audio 46 12th March 2006 11:49 PM
