alpine ivx-c806 wont power up
Old 27th August 2011, 08:18 PM   #1
mekaiver is offline mekaiver  Aland Islands
Default alpine ivx-c806 wont power up
Well as the title states, it wont power up. It has a 4 point connector at the back of the unit: illumination, GND, an empty one and B+. When B+ and GND are connected and I press the pwr button or hold it, nothing happens. I took it apart, and there are no burn marks on anything inside of it, also I checked that the connector pins and the PCB rails are all good and that the voltage applied reaches the pins and PCB. Didnt see any fuses tho. If someone has a schematic or has done something like this, maybe some advice and help.
Thanks!
Old 27th August 2011, 08:53 PM   #2
Perry Babin is offline Perry Babin  United States
Do you have the tuner?
Old 28th August 2011, 09:47 AM   #3
Nope, only the part i mentioned. A big LCD with a cd player.
Old 28th August 2011, 10:21 AM   #4
I don't think it will function like that. Hopefully someone will correct me if I'm wrong.
Old 28th August 2011, 11:04 AM   #5
So it needs at least the tuner part to power up? Okay, ill try to find the tuner part and test it then.
alpine ivx-c806 wont power upHide this!Advertise here!
MTX RTP251D wont power up Dr Zeus Car Audio 18 19th June 2011 01:53 PM
Crossfire CFA202 wont power up Dr Zeus Car Audio 8 18th November 2010 12:47 AM
Zapco system 151-A wont power up robertleo Car Audio 5 22nd August 2010 03:23 AM
Amp wont power on, just keeps blinking, help! Mach1Chris Car Audio 7 4th May 2005 03:49 PM
Copyright ©1999-2017 diyAudio
