Wondering if there is a good sub for an MJE340 ?
#2 |
How is it being used?
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
The 3rd legs goes to a diode then the other side of the diode goes to the outputs..
C3526 So guessing its the driver for the outputs.. |
#4 |
What's the voltage rating of the rail caps?
#5 |
63 volts
#6 |
The KSC2690A may be a good sub.
#7 |
Ok i put the 2690A in the amp..
Amp will power up after a fews secs it will start drawing excessive current then go into protection mode and then power back up and draw current then back in protection.. The amp will do this over and over.. Any ideas?? |
#8 |
Ok im guessing the amp doesnt like the 2690A since the outputs will get red hot..
The orginal drivers says JE340... Wondering if you have any ideas on what other transistor might work in the amp for right now so i can do some trouble shooting?? |
#9 |
Post a photo of the inside of the amp.
| First solid-state amp was from...Cerwin-Vega?!? OR not? | head_unit | Solid State | 11 | 20th October 2011 10:14 AM |
| Replacement Amp for Cerwin Vega CLS-12S? | Jdouglas | Subwoofers | 3 | 31st March 2011 10:17 PM |
| cerwin vega amp / ampzilla clone | audiohead | Solid State | 2 | 16th December 2008 04:22 PM |
| Cerwin Vega D-7 | sorenj07 | Multi-Way | 2 | 3rd March 2007 07:16 PM |
| Page generated in 0.09387 seconds (75.84% PHP - 24.16% MySQL) with 10 queries |
