Got this in for repair..
I replaced 2 defective outputs in the left channel.. Amp will not power up.. No voltage on the 1st leg of the power supply fets.. Any ideas>?? |
#2 |
Post the voltage on the 494.
Pin 1: Pin 2: Pin 3: Pin 4: Pin 5: Pin 6: Pin 7: Pin 8: Pin 9: Pin 10: Pin 11: Pin 12: Pin 13: Pin 14: Pin 15: Pin 16:
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
Pin 1: 0
Pin 2: 4.98 Pin 3: 0.07 Pin 4: 0.31 Pin 5: 1.66 Pin 6: 3.66 Pin 7: 0 Pin 8: 13.83 Pin 9: 5.12 Pin 10: 5.11 Pin 11: 13.83 Pin 12: 13.83 Pin 13: 4.98 Pin 14: 4.98 Pin 15: 4.98 Pin 16: 0 |
#4 |
You should have ~5v on the gates of the FETs.
#5 |
Ok i fixed that one i had a broken solder connection...
I have another one in for repair also.. when i power the second one up it draws excessive current... If i only hook power and ground up it will draw excessive current also.. I removed the fets and they all test fine.. Any ideas? |
#6 |
Power it up through the limiter and measure the DC voltage on the power supply FETs (black on leg 3, red on leg 1).
#7 |
I get -3.38 volts on all of them
#8 |
It can't be negative. Are the meter leads in the correct locations in the meter?
#9 |
Sorry my mistake.. I get 3.38 volts
#10 |
Did you have your probes backwards?
If so, did you have them backwards when you read 0v on the gates?
| Kenwood KAC 7202 | mike49504 | Car Audio | 10 | 25th February 2011 11:05 PM |
| Kenwood KAC-7204 | mike49504 | Car Audio | 11 | 30th December 2010 07:13 AM |
| Kenwood KAC 8101D | mike49504 | Car Audio | 5 | 14th May 2010 10:26 PM |
| Kenwood KAC-628 | mike49504 | Car Audio | 14 | 12th May 2010 10:17 PM |
| Kenwood KAC-X301T and KAC-X201T:Do they share the same board? | spooney | Car Audio | 1 | 25th October 2007 01:08 AM |
| Page generated in 0.08582 seconds (75.73% PHP - 24.27% MySQL) with 10 queries |
